Saltar al contenido principal
HTC Thunderbolt MicroSD Card Replacement
Qué necesitas
  1. HTC Thunderbolt MicroSD Card Replacement, Rear Panel: paso 1, imagen 1 de 1
    • Insert the plastic opening tool into the top of the Thunderbolt near the power button.
    • Gently pry up on the rear panel around the edges until it is loose.
  2. HTC Thunderbolt MicroSD Card Replacement: paso 2, imagen 1 de 1
    • Lift and remove the rear panel.
  3. HTC Thunderbolt MicroSD Card Replacement, Battery: paso 3, imagen 1 de 2 HTC Thunderbolt MicroSD Card Replacement, Battery: paso 3, imagen 2 de 2
    • Using the plastic opening tool, lift up the battery from the bottom near the kickstand.
    • Remove the battery from the inner frame.
  4. HTC Thunderbolt MicroSD Card Replacement, MicroSD Card: paso 4, imagen 1 de 2 HTC Thunderbolt MicroSD Card Replacement, MicroSD Card: paso 4, imagen 2 de 2
    • Use your finger to push the MicroSD card in towards the top of the phone, allowing it to be released from the casing.
  5. HTC Thunderbolt MicroSD Card Replacement: paso 5, imagen 1 de 1
    • Use tweezers to grab onto the MicroSD card and carefully remove it from the casing.
Conclusión
Vanessa
Miembro Desde 01/18/13
60 Reputación
4 Guías creadas
Equipo
Cal Poly, Team 19-45, Regan Winter 2013 Miembro de Cal Poly, Team 19-45, Regan Winter 2013
CPSU-REGAN-W13S19G45
4 Miembros
24 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 1,411
