Saltar al contenido principal
HTC Thunderbolt Camera Replacement
Qué necesitas
  1. HTC Thunderbolt Camera Replacement, Rear Panel: paso 1, imagen 1 de 1
    • Insert the plastic opening tool into the top of the Thunderbolt near the power button.
    • Gently pry up on the rear panel around the edges until it is loose.
  2. HTC Thunderbolt Camera Replacement: paso 2, imagen 1 de 1
    • Lift and remove the rear panel.
  3. HTC Thunderbolt Camera Replacement, Battery: paso 3, imagen 1 de 2 HTC Thunderbolt Camera Replacement, Battery: paso 3, imagen 2 de 2
    • Using the plastic opening tool, lift up the battery from the bottom near the kickstand.
    • Remove the battery from the inner frame.
  4. HTC Thunderbolt Camera Replacement, Rear Frame: paso 4, imagen 1 de 1
    • Remove the six Phillips screws from the perimeter of the rear frame.
    • By removing the screw with the "void" sticker on it, your Thunderbolt will no longer be covered under warranty.
  5. HTC Thunderbolt Camera Replacement: paso 5, imagen 1 de 2 HTC Thunderbolt Camera Replacement: paso 5, imagen 2 de 2
    • Insert the plastic opening tool into the bottom of the phone underneath the soft keys.
    • Gently pry up on the plastic cover by sliding the plastic opening tool across the bottom of the phone.
    • Remove the plastic cover.
    • The plastic cover will have adhesive on it making it difficult to remove.
  6. HTC Thunderbolt Camera Replacement: paso 6, imagen 1 de 1
    • Remove the two Phillips screws where the plastic cover was.
  7. HTC Thunderbolt Camera Replacement: paso 7, imagen 1 de 2 HTC Thunderbolt Camera Replacement: paso 7, imagen 2 de 2
    • Insert the plastic opening tool in between the screen and the frame on the side of the phone.
    • Slowly slide the the plastic opening tool along the side of the phone until the screen begins to separate from the frame.
    • Do the same for the opposite side of the phone.
  8. HTC Thunderbolt Camera Replacement: paso 8, imagen 1 de 3 HTC Thunderbolt Camera Replacement: paso 8, imagen 2 de 3 HTC Thunderbolt Camera Replacement: paso 8, imagen 3 de 3
    • Carefully separate the screen and phone from the rear frame, starting from the bottom.
    • Gently pull down on the phone and screen to fully separate it from the rear frame.
  9. HTC Thunderbolt Camera Replacement, Rear Inner Frame: paso 9, imagen 1 de 1
    • Remove the two Phillips screws securing rear inner frame to device.
  10. HTC Thunderbolt Camera Replacement: paso 10, imagen 1 de 1
    • Insert the plastic opening tool between the rear inner frame and the motherboard and slowly work your way around the device.
  11. HTC Thunderbolt Camera Replacement: paso 11, imagen 1 de 2 HTC Thunderbolt Camera Replacement: paso 11, imagen 2 de 2
    • Remove the rear inner frame from the rest of the device.
  12. HTC Thunderbolt Camera Replacement, LCD/Screen: paso 12, imagen 1 de 2 HTC Thunderbolt Camera Replacement, LCD/Screen: paso 12, imagen 2 de 2
    Herramienta utilizada en este paso:
    Comprar
    • Using the tip of an plastic opening tool flip up the tab holding the capacitive button ribbon cable.
    • Be careful opening these tabs as they are very easy to break.
    • Use a pair of tweezers to pull the capacitive button cable out of its socket.
  13. HTC Thunderbolt Camera Replacement: paso 13, imagen 1 de 2 HTC Thunderbolt Camera Replacement: paso 13, imagen 2 de 2
    • Lifting from the side where the ribbon was disconnected, flip over the motherboard.
    • Remove the black tape covering the tabs connecting the motherboard and LCD.
  14. HTC Thunderbolt Camera Replacement: paso 14, imagen 1 de 1
    • Using the plastic opening tool pop up the two tabs connecting the LCD and motherboard.
  15. HTC Thunderbolt Camera Replacement: paso 15, imagen 1 de 2 HTC Thunderbolt Camera Replacement: paso 15, imagen 2 de 2
    • Once the tabs have been popped up, slowly pull the two pieces away from each other.
    • If there is resistance pulling apart the phone then a ribbon or tab has not been disconnected properly/completely.
  16. HTC Thunderbolt Camera Replacement, Motherboard: paso 16, imagen 1 de 1
    • The motherboard should now be completely disconnected
  17. HTC Thunderbolt Camera Replacement, Camera: paso 17, imagen 1 de 2 HTC Thunderbolt Camera Replacement, Camera: paso 17, imagen 2 de 2
    • Use a finger nail to get in between the tape and the phone, then pull the tape off gently.
  18. HTC Thunderbolt Camera Replacement: paso 18, imagen 1 de 1
    • Pop up the tab connecting the camera to the motherboard.
  19. HTC Thunderbolt Camera Replacement: paso 19, imagen 1 de 1
    Comprar
    • Flip over motherboard and using tweezers gently grab the camera, then pull back and up.
Conclusión
Una persona más ha completado esta guía.
Vanessa
Miembro Desde 01/18/13
60 Reputación
4 Guías creadas
Equipo
Cal Poly, Team 19-45, Regan Winter 2013 Miembro de Cal Poly, Team 19-45, Regan Winter 2013
CPSU-REGAN-W13S19G45
4 Miembros
24 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 12
Todo El Tiempo: 995
