Saltar al contenido principal
Introducción
The navigation keys are the hard, directional keys on the front of the phone.
The qwerty keyboard are the soft keys on the front of the phone.
Partes
No se especificaron partes.
  1. First, flip the phone over so that the back is facing you.
    • First, flip the phone over so that the back is facing you.
  2. Next, using both thumbs, carefully push the back side of the phone's exterior up, removing it from the main section of the phone. Set this piece aside until you need to   reassemble the phone.
    • Next, using both thumbs, carefully push the back side of the phone's exterior up, removing it from the main section of the phone.
    • Set this piece aside until you need to reassemble the phone.
  3. Insert thumb and pointer finger into the notch above the battery. Pull the battery away from the rest of the phone and set it aside. Insert thumb and pointer finger into the notch above the battery. Pull the battery away from the rest of the phone and set it aside.
    • Insert thumb and pointer finger into the notch above the battery. Pull the battery away from the rest of the phone and set it aside.
  4. Kits de Reparación de Batería de MacBook Air
    A partir de $69.99
    Buy Now
    A partir de $69.99
    Buy Now
  5. To remove the back casing inside the phone, unscrew the 6 screws that are around the perimeter of the phone. To remove the back casing inside the phone, unscrew the 6 screws that are around the perimeter of the phone.
    • To remove the back casing inside the phone, unscrew the 6 screws that are around the perimeter of the phone.
  6. Carefully pull off back casing. Warning: This can be difficult, but just start pulling the back out from the front shell. As it starts to lift up, continue moving around the phone until the whole back becomes free.
    • Carefully pull off back casing.
    • Warning: This can be difficult, but just start pulling the back out from the front shell. As it starts to lift up, continue moving around the phone until the whole back becomes free.
  7. Next unscrew the top screw. Warning: Be CAREFUL because the LCD screen is still attached to the front side of the motherboard by a flexible ribbon cable.
    • Next unscrew the top screw.
    • Warning: Be CAREFUL because the LCD screen is still attached to the front side of the motherboard by a flexible ribbon cable.
  8. Pull the plastic keyboard away from the front case. Pull the plastic keyboard away from the front case. Pull the plastic keyboard away from the front case.
    • Pull the plastic keyboard away from the front case.
  9. To remove the navigation keys on the front of the phone, unscrew the four screws circled using a Philips screwdriver. Remove the navigation keys from the front of the phone. They should pop out as a unit. Remove the navigation keys from the front of the phone. They should pop out as a unit.
    • To remove the navigation keys on the front of the phone, unscrew the four screws circled using a Philips screwdriver.
    • Remove the navigation keys from the front of the phone. They should pop out as a unit.
Conclusión
Luke Plewa
Miembro Desde 22/04/11
116 Reputación
4 Guías creadas
Equipo
Cal Poly, Team 25-29, Garner Spring 2011 Miembro de Cal Poly, Team 25-29, Garner Spring 2011
CPSU-GARNER-S11S25G29
3 Miembros
5 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 1
Últimos 30 Días: 1
Todo El Tiempo: 1,512
