Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
Introducción
The display screen is protected behind the exterior plastic case of the phone.
Partes
No se especificaron partes.
  1. First, flip the phone over so that the back is facing you.
    • First, flip the phone over so that the back is facing you.
  2. Next, using both thumbs, carefully push the back side of the phone's exterior up, removing it from the main section of the phone. Set this piece aside until you need to   reassemble the phone.
    • Next, using both thumbs, carefully push the back side of the phone's exterior up, removing it from the main section of the phone.
    • Set this piece aside until you need to reassemble the phone.
  3. Insert thumb and pointer finger into the notch above the battery. Pull the battery away from the rest of the phone and set it aside. Insert thumb and pointer finger into the notch above the battery. Pull the battery away from the rest of the phone and set it aside.
    • Insert thumb and pointer finger into the notch above the battery. Pull the battery away from the rest of the phone and set it aside.
  4. Kits para Nintendo Switch
    Una solución rápida para volver al juego
    Comprar kits de Switch
  5. To remove the back casing inside the phone, use a small, pentagonal screwdriver to unscrew the 6 screws that can be found around the edges. To remove the back casing inside the phone, use a small, pentagonal screwdriver to unscrew the 6 screws that can be found around the edges.
    • To remove the back casing inside the phone, use a small, pentagonal screwdriver to unscrew the 6 screws that can be found around the edges.
  6. Carefully pull off the black casing. Warning: This can be difficult. Just start pulling the back out from the front shell and, as it starts to lift up, continue moving around the phone until the whole back becomes free.
    • Carefully pull off the black casing.
    • Warning: This can be difficult. Just start pulling the back out from the front shell and, as it starts to lift up, continue moving around the phone until the whole back becomes free.
  7. Next, unscrew the top screw using a small, Philips screwdriver. You will now be able to pull the motherboard back.
    • Next, unscrew the top screw using a small, Philips screwdriver. You will now be able to pull the motherboard back.
    • Warning: BE CAREFUL. The LCD screen is still attached to the front side of the motherboard by a flexible ribbon cable and to the front case by an adhesive.
  8. Using a spudger, remove the display screen from its cell within the front case. Insert the spudger next to the LCD on the opposite side of where the motherboard is attached. CAUTION: The LCD is attached with a sticky adhesive so it might be difficult to get off.
    • Using a spudger, remove the display screen from its cell within the front case. Insert the spudger next to the LCD on the opposite side of where the motherboard is attached.
    • CAUTION: The LCD is attached with a sticky adhesive so it might be difficult to get off.
  9. Place the motherboard down on top of LCD. Using tweezers, remove the yellow piece of tape covering the end of the flat ribbon cable.
    • Place the motherboard down on top of LCD. Using tweezers, remove the yellow piece of tape covering the end of the flat ribbon cable.
  10. Peel off the silver tape covering the flat ribbon cable. The motherboard is now free from the rest of the phone.
    • Peel off the silver tape covering the flat ribbon cable. The motherboard is now free from the rest of the phone.
    • The sticky gray tape might have to be ripped in order to be removed because of its extreme stickiness.
Conclusión
Una persona más ha completado esta guía.
Luke Plewa
Miembro Desde 22/04/11
116 Reputación
4 Guías creadas
Equipo
Cal Poly, Team 25-29, Garner Spring 2011 Miembro de Cal Poly, Team 25-29, Garner Spring 2011
CPSU-GARNER-S11S25G29
3 Miembros
5 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 1,536
