Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
HTC Rhyme Volume Button Replacement
Qué necesitas
  1. HTC Rhyme Volume Button  Replacement, Removing Back Cover: paso 1, imagen 1 de 1
    • Slide the bottom back cover off of the phone.
    Pregunta a FixBot
  2. HTC Rhyme Volume Button  Replacement: paso 2, imagen 1 de 1
    • Locate the four screws on the plastic cover and unscrew them.
    Pregunta a FixBot
  3. HTC Rhyme Volume Button  Replacement: paso 3, imagen 1 de 1
    • Pry the sticker off from the sides.
    • You can use a metal spudger to do this.
    • Peel the sticker off with your hands.
    Pregunta a FixBot
  4. HTC Rhyme Volume Button  Replacement, Remove the plastic cover: paso 4, imagen 1 de 1
    • Remove the plastic cover using your hands.
    Pregunta a FixBot
  5. HTC Rhyme Volume Button  Replacement: paso 5, imagen 1 de 1
    • Remove the yellow ribbon.
    Pregunta a FixBot
  6. HTC Rhyme Volume Button  Replacement: paso 6, imagen 1 de 3 HTC Rhyme Volume Button  Replacement: paso 6, imagen 2 de 3 HTC Rhyme Volume Button  Replacement: paso 6, imagen 3 de 3
    • Lift up the blue flaps underneath the battery.
    • Lift up the black flap at the top of the phone.
    • Lift up the black flap at the bottom of the phone.
    Pregunta a FixBot
  7. HTC Rhyme Volume Button  Replacement, Remove the Motherboard: paso 7, imagen 1 de 2 HTC Rhyme Volume Button  Replacement, Remove the Motherboard: paso 7, imagen 2 de 2
    • Remove all 4 screws.
    • Carefully remove the motherboard with your hands.
    Pregunta a FixBot
  8. HTC Rhyme Volume Button  Replacement, Removing the back plastic casing: paso 8, imagen 1 de 3 HTC Rhyme Volume Button  Replacement, Removing the back plastic casing: paso 8, imagen 2 de 3 HTC Rhyme Volume Button  Replacement, Removing the back plastic casing: paso 8, imagen 3 de 3
    • Pry the back plastic casing off with your hands.
    Pregunta a FixBot
  9. HTC Rhyme Volume Button  Replacement: paso 9, imagen 1 de 2 HTC Rhyme Volume Button  Replacement: paso 9, imagen 2 de 2
    • Use the tip of a screwdriver to push the button out of the panel.
    Pregunta a FixBot
Conclusión
Frederick
Miembro Desde 10/08/14
119 Reputación
1 Guía escrita
Equipo
USF Tampa, Team 9-6, Leahy Fall 2014 Miembro de USF Tampa, Team 9-6, Leahy Fall 2014
USFT-LEAHY-F14S9G6
Miembros de 3
10 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 4
Ultimos 30 días: 42
Todo El Tiempo: 448
