Saltar al contenido principal
HTC Rhyme Battery Replacement
Qué necesitas
  1. HTC Rhyme Battery Replacement, Removing Back Cover: paso 1, imagen 1 de 2 HTC Rhyme Battery Replacement, Removing Back Cover: paso 1, imagen 2 de 2
    • Slide the bottom back cover off of the phone.
  2. HTC Rhyme Battery Replacement: paso 2, imagen 1 de 1
    • Locate the four screws on the plastic cover and unscrew them.
  3. HTC Rhyme Battery Replacement: paso 3, imagen 1 de 2 HTC Rhyme Battery Replacement: paso 3, imagen 2 de 2
    • Pry the sticker off from the sides.
    • You can use a metal spudger to do this.
    • Peel the sticker off with your hands.
  4. HTC Rhyme Battery Replacement, Remove the plastic cover: paso 4, imagen 1 de 1
    • Remove the plastic cover using your hands.
  5. HTC Rhyme Battery Replacement: paso 5, imagen 1 de 1
    • Remove the yellow ribbon.
  6. HTC Rhyme Battery Replacement: paso 6, imagen 1 de 3 HTC Rhyme Battery Replacement: paso 6, imagen 2 de 3 HTC Rhyme Battery Replacement: paso 6, imagen 3 de 3
    • Lift up the blue flaps underneath the battery.
    • Lift up the black flap at the top of the phone.
    • Lift up the black flap at the bottom of the phone.
  7. HTC Rhyme Battery Replacement, Remove the Motherboard: paso 7, imagen 1 de 2 HTC Rhyme Battery Replacement, Remove the Motherboard: paso 7, imagen 2 de 2
    • Remove all 4 screws.
    • Carefully remove the motherboard with your hands.
  8. HTC Rhyme Battery Replacement, Removing the Back Plastic Casing: paso 8, imagen 1 de 3 HTC Rhyme Battery Replacement, Removing the Back Plastic Casing: paso 8, imagen 2 de 3 HTC Rhyme Battery Replacement, Removing the Back Plastic Casing: paso 8, imagen 3 de 3
    • Pry the back plastic casing off with your hands.
  9. HTC Rhyme Battery Replacement, Removing the Battery: paso 9, imagen 1 de 3 HTC Rhyme Battery Replacement, Removing the Battery: paso 9, imagen 2 de 3 HTC Rhyme Battery Replacement, Removing the Battery: paso 9, imagen 3 de 3
    • Remove the screws.
    • Use a metal spudger to remove the battery.
Conclusión
2 personas más completaron esta guía.
Elizabeth Steiner
Miembro Desde 10/08/14
435 Reputación
3 Guías creadas
Equipo
USF Tampa, Team 9-6, Leahy Fall 2014 Miembro de USF Tampa, Team 9-6, Leahy Fall 2014
USFT-LEAHY-F14S9G6
3 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 4
Todo El Tiempo: 5,040
