Saltar al contenido principal
HTC Radar 4G Touch Digitizer Replacement
Qué necesitas
  1. HTC Radar 4G Touch Digitizer Replacement, Touch Digitizer: paso 1, imagen 1 de 2 HTC Radar 4G Touch Digitizer Replacement, Touch Digitizer: paso 1, imagen 2 de 2
    • Slide the lower plastic panel off of the phone.
    • Remove the four screws from the white plastic cover of the phone using the T5 Torx screwdriver.
    • Remove the two black screws from the silver frame.
  2. HTC Radar 4G Touch Digitizer Replacement: paso 2, imagen 1 de 1
    • Remove the back cover by pressing on the back of the motherboard lightly and pulling the screen out carefully.
  3. HTC Radar 4G Touch Digitizer Replacement: paso 3, imagen 1 de 1
    • Remove the battery from the phone using a fingernail or an opening pick.
  4. HTC Radar 4G Touch Digitizer Replacement: paso 4, imagen 1 de 1
    • Remove the three screws using a screwdriver.
    • Remove the plastic frame.
  5. HTC Radar 4G Touch Digitizer Replacement: paso 5, imagen 1 de 3 HTC Radar 4G Touch Digitizer Replacement: paso 5, imagen 2 de 3 HTC Radar 4G Touch Digitizer Replacement: paso 5, imagen 3 de 3
    • Remove the upper board and motherboard from the phone using an opening tool.
    • The regular black nylon spudger should be used whenever possible, especially around motherboards.
  6. HTC Radar 4G Touch Digitizer Replacement: paso 6, imagen 1 de 2 HTC Radar 4G Touch Digitizer Replacement: paso 6, imagen 2 de 2
    • Use your hands to remove the touch digitizer.
Conclusión
Kevin Guerra
Miembro Desde 10/10/16
101 Reputación
1 Guía escrita
Equipo
Texas Tech, Team 12-5, Bennett Fall 2016 Miembro de Texas Tech, Team 12-5, Bennett Fall 2016
TTU-BENNETT-F16S12G5
4 Miembros
2 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 13
Todo El Tiempo: 287
