Saltar al contenido principal
HTC Ozone Motherboard Replacement
Qué necesitas
  1. HTC Ozone Motherboard Replacement, Rear Battery Cover: paso 1, imagen 1 de 1
    • Flip the phone over to have the rear cover facing up.
    • The camera lens should be towards the top of the phone.
  2. HTC Ozone Motherboard Replacement: paso 2, imagen 1 de 2 HTC Ozone Motherboard Replacement: paso 2, imagen 2 de 2
    • Slide the cover up, towards the top of phone, to unlock the battery cover.
    • Lift the cover off phone and remove it.
  3. HTC Ozone Motherboard Replacement, Battery: paso 3, imagen 1 de 3 HTC Ozone Motherboard Replacement, Battery: paso 3, imagen 2 de 3 HTC Ozone Motherboard Replacement, Battery: paso 3, imagen 3 de 3
    • Use your finger to push the top of the battery downwards and lift the battery out of the phone.
  4. HTC Ozone Motherboard Replacement, Frame: paso 4, imagen 1 de 3 HTC Ozone Motherboard Replacement, Frame: paso 4, imagen 2 de 3 HTC Ozone Motherboard Replacement, Frame: paso 4, imagen 3 de 3
    • Remove the six Torx #5 screws that are securing the rear frame.
  5. HTC Ozone Motherboard Replacement: paso 5, imagen 1 de 3 HTC Ozone Motherboard Replacement: paso 5, imagen 2 de 3 HTC Ozone Motherboard Replacement: paso 5, imagen 3 de 3
    Herramienta utilizada en este paso:
    Plastic Cards
    $2.99
    Comprar
    • Pry the frame open, releasing the eight plastic tabs around the edge of the frame, using the plastic opening tool.
    • A plastic card can be used instead of the plastic opening tool.
  6. HTC Ozone Motherboard Replacement, Motherboard: paso 6, imagen 1 de 2 HTC Ozone Motherboard Replacement, Motherboard: paso 6, imagen 2 de 2
    • Remove the single Phillips #0 screw that is securing the motherboard to the front case of the phone.
  7. HTC Ozone Motherboard Replacement: paso 7, imagen 1 de 2 HTC Ozone Motherboard Replacement: paso 7, imagen 2 de 2
    • Pry the motherboard away from the front of the plastic case using a plastic opening tool.
    • Be careful not to break the ribbon cable when prying away the motherboard.
  8. HTC Ozone Motherboard Replacement: paso 8, imagen 1 de 3 HTC Ozone Motherboard Replacement: paso 8, imagen 2 de 3 HTC Ozone Motherboard Replacement: paso 8, imagen 3 de 3
    • Remove the plastic cover from the LCD display and the motherboard.
    • The Motherboard and the LCD are still attached together.
Conclusión
Una persona más ha completado esta guía.
Marco Jokada
Miembro Desde 04/28/11
247 Reputación
6 Guías creadas
Equipo
Un comentario
Where can I buy/find/get this motherboard? I have been looking for one for over a year now, thanks
Walt - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 3
Todo El Tiempo: 1,529
