Saltar al contenido principal
HTC One X Plus Top Speaker Replacement
Qué necesitas
  1. HTC One X Plus Top Speaker Replacement, Top Speaker: paso 1, imagen 1 de 1
    • Hold down the power button to turn off your device.
    • Insert a pin, paper clip, or another similar object into the hole next to the micro sim card holder to remove it.
    • The SIM card slot is located on the top edge of the device.
  2. HTC One X Plus Top Speaker Replacement: paso 2, imagen 1 de 3 HTC One X Plus Top Speaker Replacement: paso 2, imagen 2 de 3 HTC One X Plus Top Speaker Replacement: paso 2, imagen 3 de 3
    • Using plastic opening tools, pry open the bottom of the device.
    • You will hear clicking sounds as the sides of the device detach from the screen.
    • Once both sides are detached use the suction cup tool to remove the screen completely from the black casing.
  3. HTC One X Plus Top Speaker Replacement: paso 3, imagen 1 de 3 HTC One X Plus Top Speaker Replacement: paso 3, imagen 2 de 3 HTC One X Plus Top Speaker Replacement: paso 3, imagen 3 de 3
    • Remove the five 2.4mm screws located around the camera using a Philips head screwdriver to remove the plastic cover.
    • Once you have disassembled your device the warranty will no longer be valid.
  4. HTC One X Plus Top Speaker Replacement: paso 4, imagen 1 de 3 HTC One X Plus Top Speaker Replacement: paso 4, imagen 2 de 3 HTC One X Plus Top Speaker Replacement: paso 4, imagen 3 de 3
    • Use the J000 Philips screwdriver to remove the screws and remove the PCB board and antenna.
    • These are two 3.4mm Philips head screws found in the lower right corner of the phone.
  5. HTC One X Plus Top Speaker Replacement: paso 5, imagen 1 de 2 HTC One X Plus Top Speaker Replacement: paso 5, imagen 2 de 2
    Herramienta utilizada en este paso:
    • Pull out the power button flex cable using tweezers to disconnect from the phone.
    • Use the tweezers to then disconnect the touch screen flex cable.
  6. HTC One X Plus Top Speaker Replacement: paso 6, imagen 1 de 3 HTC One X Plus Top Speaker Replacement: paso 6, imagen 2 de 3 HTC One X Plus Top Speaker Replacement: paso 6, imagen 3 de 3
    • Remove the battery connections to the logic board.
    • This is the six pin connector seen in the red box.
    • Pull the battery away to remove from the back of the screen.
  7. HTC One X Plus Top Speaker Replacement: paso 7, imagen 1 de 2 HTC One X Plus Top Speaker Replacement: paso 7, imagen 2 de 2
    • CAUTION: carefully remove the top speaker from the phone using tweezers.
Conclusión
Una persona más ha completado esta guía.
Jason Melo
Miembro Desde 08/26/15
483 Reputación
4 Guías creadas
Equipo
USF Tampa, Team 3-3, Eyestone Fall 2015 Miembro de USF Tampa, Team 3-3, Eyestone Fall 2015
USFT-EYESTONE-F15S3G3
Miembros de 3
10 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 7
Todo El Tiempo: 491
