Saltar al contenido principal
HTC One X Plus Screen Replacement
Qué necesitas
  1. HTC One X Plus Screen Replacement, Screen: paso 1, imagen 1 de 1
    • Power off your device.
    • Insert a pin, paper clip, or very small piece of metal in the hole next to the micro sim card holder to remove it.
    • The sim card slot is located on the top edge of the device.
  2. HTC One X Plus Screen Replacement: paso 2, imagen 1 de 3 HTC One X Plus Screen Replacement: paso 2, imagen 2 de 3 HTC One X Plus Screen Replacement: paso 2, imagen 3 de 3
    • Using plastic opening tools, pry open the bottom of the device first.
    • You will hear clicking sounds as the sides of the device detach from the screen.
    • Once both sides are detached, use the suction cup tool to remove the screen completely from the black encasing.
  3. HTC One X Plus Screen Replacement: paso 3, imagen 1 de 3 HTC One X Plus Screen Replacement: paso 3, imagen 2 de 3 HTC One X Plus Screen Replacement: paso 3, imagen 3 de 3
    • Remove the five 2.4 mm screws using a Phillips #000 screwdriver.
    • Remove the plastic cover.
  4. HTC One X Plus Screen Replacement: paso 4, imagen 1 de 3 HTC One X Plus Screen Replacement: paso 4, imagen 2 de 3 HTC One X Plus Screen Replacement: paso 4, imagen 3 de 3
    • Use a Phillips #000 screwdriver to remove the two 3.4 mm screws.
    • Remove the PCB board and antenna.
  5. HTC One X Plus Screen Replacement: paso 5, imagen 1 de 2 HTC One X Plus Screen Replacement: paso 5, imagen 2 de 2
    • Use tweezers to disconnect the power button flex cable.
  6. HTC One X Plus Screen Replacement: paso 6, imagen 1 de 3 HTC One X Plus Screen Replacement: paso 6, imagen 2 de 3 HTC One X Plus Screen Replacement: paso 6, imagen 3 de 3
    • Disconnect the battery's six pin connector from the motherboard.
    • Remove the battery by pulling it upwards.
  7. HTC One X Plus Screen Replacement: paso 7, imagen 1 de 1
    • Disconnect the screen from the digitizer.
    • Use a plastic opening tool to gently disconnect the screen from the digitizer.
    • You may have to use heat to loosen adhesive securing the screen.
Conclusión
Jason Melo
Miembro Desde 08/26/15
483 Reputación
4 Guías creadas
Equipo
USF Tampa, Team 3-3, Eyestone Fall 2015 Miembro de USF Tampa, Team 3-3, Eyestone Fall 2015
USFT-EYESTONE-F15S3G3
3 Miembros
10 Guías creadas
Un comentario
Man, this did nothing but break my International One X+. There were so many instructions missing.
Garrett Reyman - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 1
Todo El Tiempo: 1,804
