Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
HTC One X Plus Motherboard Replacement
Qué necesitas
  1. HTC One X Plus Motherboard Replacement, Motherboard: paso 1, imagen 1 de 1
    • Power off your device.
    • Insert a pin, paper clip, or very small piece of metal into the hole next to the micro sim card holder to remove it.
    • The Sim Card Slot is located on the top edge of the device.
  2. HTC One X Plus Motherboard Replacement: paso 2, imagen 1 de 3 HTC One X Plus Motherboard Replacement: paso 2, imagen 2 de 3 HTC One X Plus Motherboard Replacement: paso 2, imagen 3 de 3
    • Using plastic opening tools, pry open the bottom of the device first.
    • You will hear clicking sounds as the sides of the device detach from the screen.
    • Once both sides are detached, use the suction cup tool to remove the screen completely from the black encasing.
  3. HTC One X Plus Motherboard Replacement: paso 3, imagen 1 de 3 HTC One X Plus Motherboard Replacement: paso 3, imagen 2 de 3 HTC One X Plus Motherboard Replacement: paso 3, imagen 3 de 3
    • Using a Philips head screw driver, remove the five 2.4mm screws that are pictured. Then remove the plastic cover.
    • Once you have disassembled your device the warranty will no longer be valid.
  4. HTC One X Plus Motherboard Replacement: paso 4, imagen 1 de 3 HTC One X Plus Motherboard Replacement: paso 4, imagen 2 de 3 HTC One X Plus Motherboard Replacement: paso 4, imagen 3 de 3
    • Use the J000 Philips screw driver head to remove the screws as pictured.
    • There are two 3.4mm screws to be removed.
    • Remove the PCB board and the antenna.
  5. HTC One X Plus Motherboard Replacement: paso 5, imagen 1 de 2 HTC One X Plus Motherboard Replacement: paso 5, imagen 2 de 2
    Herramienta utilizada en este paso:
    • Using tweezers, disconnect the power button flex cable.
    • Then disconnect the touch screen flex cable.
  6. HTC One X Plus Motherboard Replacement: paso 6, imagen 1 de 3 HTC One X Plus Motherboard Replacement: paso 6, imagen 2 de 3 HTC One X Plus Motherboard Replacement: paso 6, imagen 3 de 3
    • Disconnect the battery from the logic board.
    • Look for a white six pin connector.
    • Remove the battery by pulling upwards.
  7. HTC One X Plus Motherboard Replacement: paso 7, imagen 1 de 1
    • Disconnect the remaining two flex cables following the same procedure from Step 5.
    • Once these two flex cables have been disconnected, you may now remove the motherboard.
Conclusión
Una persona más ha completado esta guía.
Jason Melo
Miembro Desde 08/26/15
483 Reputación
4 Guías creadas
Equipo
USF Tampa, Team 3-3, Eyestone Fall 2015 Miembro de USF Tampa, Team 3-3, Eyestone Fall 2015
USFT-EYESTONE-F15S3G3
Miembros de 3
10 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 13
Todo El Tiempo: 1,408
