Saltar al contenido principal
HTC One X Plus Battery Replacement
Qué necesitas
  1. HTC One X Plus Battery Replacement, Battery: paso 1, imagen 1 de 1
    • Power off your device.
    • Insert a pin, paper clip, or very small piece of metal into the hole next to the micro SIM card holder to remove it.
    • The SIM card slot is located on the top edge of the device.
  2. HTC One X Plus Battery Replacement: paso 2, imagen 1 de 3 HTC One X Plus Battery Replacement: paso 2, imagen 2 de 3 HTC One X Plus Battery Replacement: paso 2, imagen 3 de 3
    • Using plastic opening tools, pry open the bottom of the device first.
    • You will hear clicking sounds as the sides of the device detach from the screen.
    • Once both sides are detached use the suction cup tool to remove the screen completely from the black casing.
  3. HTC One X Plus Battery Replacement: paso 3, imagen 1 de 3 HTC One X Plus Battery Replacement: paso 3, imagen 2 de 3 HTC One X Plus Battery Replacement: paso 3, imagen 3 de 3
    • Remove the five 2.4mm screws using a Phillips head screw driver and then remove the plastic cover.
  4. HTC One X Plus Battery Replacement: paso 4, imagen 1 de 3 HTC One X Plus Battery Replacement: paso 4, imagen 2 de 3 HTC One X Plus Battery Replacement: paso 4, imagen 3 de 3
    • Remove the two 3.4 mm JIS #000 screws from the PCB board.
    • Remove the PCB board and antenna.
  5. HTC One X Plus Battery Replacement: paso 5, imagen 1 de 2 HTC One X Plus Battery Replacement: paso 5, imagen 2 de 2
    Herramienta utilizada en este paso:
    • Use tweezers to disconnect the power button flex cable.
    • Disconnect the touch screen flex cable
  6. HTC One X Plus Battery Replacement: paso 6, imagen 1 de 3 HTC One X Plus Battery Replacement: paso 6, imagen 2 de 3 HTC One X Plus Battery Replacement: paso 6, imagen 3 de 3
    • Disconnect the battery from the logic board by detaching the six pin connector.
    • Remove the battery by pulling upwards.
Conclusión
3 personas más completaron esta guía.
Vitterio Crisp
Miembro Desde 08/26/15
119 Reputación
1 Guía escrita
Equipo
USF Tampa, Team 3-3, Eyestone Fall 2015 Miembro de USF Tampa, Team 3-3, Eyestone Fall 2015
USFT-EYESTONE-F15S3G3
Miembros de 3
10 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 16
Todo El Tiempo: 4,200
