Saltar al contenido principal
HTC One X Plus Antenna Replacement
Qué necesitas
  1. HTC One X Plus Antenna Replacement, Antenna: paso 1, imagen 1 de 1
    • Power off your device.
    • Insert a pin, paper clip, or very small piece of metal into the hole next to the micro-SIM card holder to remove it.
    • The SIM card slot is located on the top edge of the device.
  2. HTC One X Plus Antenna Replacement: paso 2, imagen 1 de 3 HTC One X Plus Antenna Replacement: paso 2, imagen 2 de 3 HTC One X Plus Antenna Replacement: paso 2, imagen 3 de 3
    • Using the plastic opening tools, pry open the bottom of the device first.
    • You will hear clicking sounds as the sides of the device detach from the screen.
    • Once both sides are detached, use the suction cup tool to remove the screen completely from the black encasing.
  3. HTC One X Plus Antenna Replacement: paso 3, imagen 1 de 1
    Herramienta utilizada en este paso:
    • Now that the rear panel has been removed, use the metal tweezers to carefully remove the antenna.
    • The antenna is the loose black wire located to the right of the battery.
    • Using the metal tweezers, connect and install your new antenna, securing the antenna beneath the metal supports.
Conclusión
2 personas más completaron esta guía.
Jason Melo
Miembro Desde 08/26/15
483 Reputación
4 Guías creadas
Equipo
USF Tampa, Team 3-3, Eyestone Fall 2015 Miembro de USF Tampa, Team 3-3, Eyestone Fall 2015
USFT-EYESTONE-F15S3G3
Miembros de 3
10 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 8
Todo El Tiempo: 774
