Introducción
If rebooting your device or updating the software to the latest version doesn't solve your wi-fi or bluetooth connectivity, then another easy fix can be to replace your HTC One X antenna.
Qué necesitas
Before replacement of the antenna, carry out the squeeze test.
Gently squeeze your device between the camera lens and the volume button. This should temporarily reconnect the antenna if it's loose.
If the squeeze test doesn't reconnect your wi-fi/bluetooth then move to step 2
Insert a safety pin, or other small object into the narrow aperture next to the Sim Card Slot to remove the SIM card.
Use a plastic opening tool, and carefully insert it between the display and rear panel. Separate the two parts.
Set aside the rear panel for now
Once the rear panel is separated from the front panel, remove the antenna using tweezers.
Replace and reconnect the new antenna in the same position as the faulty one you just removed. Remember to place it underneath the metal supports on the board.
4 personas más completaron esta guía.
