Saltar al contenido principal
HTC One Mini Rear Facing Camera Replacement
Qué necesitas
  1. HTC One Mini Rear Facing Camera Replacement, iOpener Heating: paso 1, imagen 1 de 1
    • Use an iOpener or hair dryer to apply heat to the lower speaker grille, in order to soften the adhesive underneath.
  2. HTC One Mini Rear Facing Camera Replacement, Remove Speaker Grills: paso 2, imagen 1 de 1
    • Slide a thin pry tool underneath the lower speaker cover and slide it across to separate the adhesive underneath.
    • Remove the lower speaker cover.
  3. HTC One Mini Rear Facing Camera Replacement, Remove Screw: paso 3, imagen 1 de 3 HTC One Mini Rear Facing Camera Replacement, Remove Screw: paso 3, imagen 2 de 3 HTC One Mini Rear Facing Camera Replacement, Remove Screw: paso 3, imagen 3 de 3
    • Remove the screw under the speaker cover using a T6 Torx screwdriver.
  4. HTC One Mini Rear Facing Camera Replacement: paso 4, imagen 1 de 3 HTC One Mini Rear Facing Camera Replacement: paso 4, imagen 2 de 3 HTC One Mini Rear Facing Camera Replacement: paso 4, imagen 3 de 3
    • Slide a thin guitar pick or pry tool between the edge of the display and the rear case, near the bottom of the phone.
    • Carefully work your way up each side of the display and separate the rear case. There are three clips on each side.
  5. HTC One Mini Rear Facing Camera Replacement, Separate Rear Case: paso 5, imagen 1 de 2 HTC One Mini Rear Facing Camera Replacement, Separate Rear Case: paso 5, imagen 2 de 2
    • Remove the rear case from the phone.
  6. HTC One Mini Rear Facing Camera Replacement, Remove Screws: paso 6, imagen 1 de 3 HTC One Mini Rear Facing Camera Replacement, Remove Screws: paso 6, imagen 2 de 3 HTC One Mini Rear Facing Camera Replacement, Remove Screws: paso 6, imagen 3 de 3
    • Remove the two Phillips screws securing the battery connector.
  7. HTC One Mini Rear Facing Camera Replacement: paso 7, imagen 1 de 2 HTC One Mini Rear Facing Camera Replacement: paso 7, imagen 2 de 2
    • Disconnect the battery by prying the metal cover straight up.
  8. HTC One Mini Rear Facing Camera Replacement, Remove screws: paso 8, imagen 1 de 3 HTC One Mini Rear Facing Camera Replacement, Remove screws: paso 8, imagen 2 de 3 HTC One Mini Rear Facing Camera Replacement, Remove screws: paso 8, imagen 3 de 3
    • Remove two Phillips screws.
    • The screw on the upper right corner secures a tiny golden washer. Remove this washer.
  9. HTC One Mini Rear Facing Camera Replacement, Remove Screws: paso 9, imagen 1 de 3 HTC One Mini Rear Facing Camera Replacement, Remove Screws: paso 9, imagen 2 de 3 HTC One Mini Rear Facing Camera Replacement, Remove Screws: paso 9, imagen 3 de 3
    • Remove the two small black Phillips screws.
  10. HTC One Mini Rear Facing Camera Replacement, Remove Screws: paso 10, imagen 1 de 3 HTC One Mini Rear Facing Camera Replacement, Remove Screws: paso 10, imagen 2 de 3 HTC One Mini Rear Facing Camera Replacement, Remove Screws: paso 10, imagen 3 de 3
    • Remove two more Phillips screws.
  11. HTC One Mini Rear Facing Camera Replacement, Remove protective foil.: paso 11, imagen 1 de 3 HTC One Mini Rear Facing Camera Replacement, Remove protective foil.: paso 11, imagen 2 de 3 HTC One Mini Rear Facing Camera Replacement, Remove protective foil.: paso 11, imagen 3 de 3
    Herramienta utilizada en este paso:
    Comprar
    • Use tweezers to remove the yellow tape covering the flex cable connectors (total of five).
  12. HTC One Mini Rear Facing Camera Replacement: paso 12, imagen 1 de 2 HTC One Mini Rear Facing Camera Replacement: paso 12, imagen 2 de 2
    • Carefully disconnect the flex cables at the points where you removed the yellow tape in the previous steps.
    • To disconnect, flip up the small latch on each connector, opposite its cable, and then gently pull the cable free.
  13. HTC One Mini Rear Facing Camera Replacement: paso 13, imagen 1 de 3 HTC One Mini Rear Facing Camera Replacement: paso 13, imagen 2 de 3 HTC One Mini Rear Facing Camera Replacement: paso 13, imagen 3 de 3
    • Peel off the silver strip with your tweezers.
    • Using your hands, detach the black strip from the board without removing it.
  14. HTC One Mini Rear Facing Camera Replacement: paso 14, imagen 1 de 2 HTC One Mini Rear Facing Camera Replacement: paso 14, imagen 2 de 2
    • Detach carefully with your tweezers the volume buttons.
    • Detach the power button with your tweezers.
  15. HTC One Mini Rear Facing Camera Replacement: paso 15, imagen 1 de 3 HTC One Mini Rear Facing Camera Replacement: paso 15, imagen 2 de 3 HTC One Mini Rear Facing Camera Replacement: paso 15, imagen 3 de 3
    • Identify the screw behind the cable.
    • Remove the screw using a Phillips screwdriver.
  16. HTC One Mini Rear Facing Camera Replacement: paso 16, imagen 1 de 2 HTC One Mini Rear Facing Camera Replacement: paso 16, imagen 2 de 2
    • Lift the motherboard, but don't try to remove it completely yet.
    • Handle the board only by the edges.
  17. HTC One Mini Rear Facing Camera Replacement: paso 17, imagen 1 de 3 HTC One Mini Rear Facing Camera Replacement: paso 17, imagen 2 de 3 HTC One Mini Rear Facing Camera Replacement: paso 17, imagen 3 de 3
    • Using your tweezers, remove the black square located in the power button.
    • Remove the motherboard completely.
  18. HTC One Mini Rear Facing Camera Replacement, Rear Facing Camera: paso 18, imagen 1 de 1
    • Remove the motherboard and place it so that the rear camera is face down.
  19. HTC One Mini Rear Facing Camera Replacement: paso 19, imagen 1 de 1
    Comprar
    • Use the tweezers to carefully peel back the copper tape attached to your rear camera.
  20. HTC One Mini Rear Facing Camera Replacement: paso 20, imagen 1 de 3 HTC One Mini Rear Facing Camera Replacement: paso 20, imagen 2 de 3 HTC One Mini Rear Facing Camera Replacement: paso 20, imagen 3 de 3
    • Use the tweezers to lift the hatch and remove the part of the rear camera that is inserted.
Conclusión
2 personas más completaron esta guía.
Marina Sanchez
Miembro Desde 09/22/14
190 Reputación
1 Guía escrita
Equipo
USF Tampa, Team 3-4, Brown Fall 2014 Miembro de USF Tampa, Team 3-4, Brown Fall 2014
USFT-BROWN-F14S3G4
3 Miembros
10 Guías creadas
2 comentarios
What glue does one use when putting back the speaker grill?
Ratfink - Contestar
where can I get the rear camera? what is te number part. tks
Sinuhe Less - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 11
Todo El Tiempo: 3,043
