Saltar al contenido principal
HTC One Mini Rear Case Replacement
Qué necesitas
  1. HTC One Mini Rear Case Replacement, iOpener Heating: paso 1, imagen 1 de 1
    • Use an iOpener or hair dryer to apply heat to the lower speaker grille, in order to soften the adhesive underneath.
  2. HTC One Mini Rear Case Replacement, Remove Speaker Grills: paso 2, imagen 1 de 1
    • Slide a thin pry tool underneath the lower speaker cover and slide it across to separate the adhesive underneath.
    • Remove the lower speaker cover.
  3. HTC One Mini Rear Case Replacement, Remove Screw: paso 3, imagen 1 de 3 HTC One Mini Rear Case Replacement, Remove Screw: paso 3, imagen 2 de 3 HTC One Mini Rear Case Replacement, Remove Screw: paso 3, imagen 3 de 3
    • Remove the screw under the speaker cover using a T6 Torx screwdriver.
  4. HTC One Mini Rear Case Replacement: paso 4, imagen 1 de 3 HTC One Mini Rear Case Replacement: paso 4, imagen 2 de 3 HTC One Mini Rear Case Replacement: paso 4, imagen 3 de 3
    • Slide a thin guitar pick or pry tool between the edge of the display and the rear case, near the bottom of the phone.
    • Carefully work your way up each side of the display and separate the rear case. There are three clips on each side.
  5. HTC One Mini Rear Case Replacement, Separate Rear Case: paso 5, imagen 1 de 2 HTC One Mini Rear Case Replacement, Separate Rear Case: paso 5, imagen 2 de 2
    • Remove the rear case from the phone.
Conclusión
3 personas más completaron esta guía.
Chris Jose
Miembro Desde 09/22/14
735 Reputación
2 Guías creadas
Equipo
USF Tampa, Team 3-4, Brown Fall 2014 Miembro de USF Tampa, Team 3-4, Brown Fall 2014
USFT-BROWN-F14S3G4
3 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 4
Todo El Tiempo: 6,896
