Saltar al contenido principal
HTC One Mini 2 Back Plate Replacement
Qué necesitas
  1. HTC One Mini 2 Back Plate Replacement, Sim and MicroSD Card: paso 1, imagen 1 de 3 HTC One Mini 2 Back Plate Replacement, Sim and MicroSD Card: paso 1, imagen 2 de 3 HTC One Mini 2 Back Plate Replacement, Sim and MicroSD Card: paso 1, imagen 3 de 3
    • Insert the end of a paper clip into the holes on each side of the phone to eject the SIM card and Micro SD card.
    • Set the cardholders aside.
  2. HTC One Mini 2 Back Plate Replacement: paso 2, imagen 1 de 1
    • Heat up the top grey speaker plate with the iFixit iOpener for two minutes.
  3. HTC One Mini 2 Back Plate Replacement, Front Plate: paso 3, imagen 1 de 3 HTC One Mini 2 Back Plate Replacement, Front Plate: paso 3, imagen 2 de 3 HTC One Mini 2 Back Plate Replacement, Front Plate: paso 3, imagen 3 de 3
    • Use a metal spudger to pry up the left edge of the upper grey front plate.
    • Place the spudger between the inside white plastic edge and the grey plate. Do not pry between the two white plastic frames.
    • Don’t pry against the glass. Pry against only the left side as there is a delicate antenna under the plate.
    • Use the narrow plastic pry tool to carefully separate the black ribbon antenna from the grey plate.
  4. HTC One Mini 2 Back Plate Replacement: paso 4, imagen 1 de 2 HTC One Mini 2 Back Plate Replacement: paso 4, imagen 2 de 2
    • Remove the 2mm screw with a T5 torx screwdriver head from the iFixit tool kit.
  5. HTC One Mini 2 Back Plate Replacement: paso 5, imagen 1 de 2 HTC One Mini 2 Back Plate Replacement: paso 5, imagen 2 de 2
    • Use the plastic pry tool to pry around the edge of the phone.
    • Pry carefully around the card slots.
    • Slowly pull up from the right side of the screen like opening a book.
    • The plastic piece for the power button may fall out. Set it aside for reassembly.
    • Use the plastic spudger to peel the foam adhesive around the camera away from the back plate.
Conclusión
5 personas más completaron esta guía.
Caleb Kelsay
Miembro Desde 10/14/14
590 Reputación
1 Guía escrita
Equipo
Cal Poly, Team 4-48, Amido Fall 2014 Miembro de Cal Poly, Team 4-48, Amido Fall 2014
CPSU-AMIDO-F14S4G48
5 Miembros
17 Guías creadas
Un comentario
what is the black ribbon antenna on the front
deancvijic90 - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 5
Todo El Tiempo: 10,264
