Saltar al contenido principal
HTC One Max Microphone and Speaker Assembly Replacement
Qué necesitas
  1. HTC One Max Microphone and Speaker Assembly Replacement, Back Case: paso 1, imagen 1 de 1
    • Lift back cover while pressing highlighted release switch towards the center of the phone.
  2. HTC One Max Microphone and Speaker Assembly Replacement: paso 2, imagen 1 de 2 HTC One Max Microphone and Speaker Assembly Replacement: paso 2, imagen 2 de 2
    • Remove the four white stickers in each corner that cover the Tri-Wing screws.
    • Remove the white sticker near the buttons that control the volume.
    • Remove the white sticker near the SIM card.
    • Remove the big white sticker with the bar-code in the center of the phone.
  3. HTC One Max Microphone and Speaker Assembly Replacement: paso 3, imagen 1 de 1
    • Remove the thirteen Tri-Wing Y00 screws (Upper & Lower screws are 5 mm length, middle screws are 3.8 mm length) from the back case.
    • Disconnect the cable near the volume buttons.
  4. HTC One Max Microphone and Speaker Assembly Replacement: paso 4, imagen 1 de 2 HTC One Max Microphone and Speaker Assembly Replacement: paso 4, imagen 2 de 2
    • Use the small plastic opening tool to pry between the screen and the rear case.
  5. HTC One Max Microphone and Speaker Assembly Replacement, Fingerprint Sensor: paso 5, imagen 1 de 2 HTC One Max Microphone and Speaker Assembly Replacement, Fingerprint Sensor: paso 5, imagen 2 de 2
    • Use Tweezers to disconnect the ribbon cable connecting the fingerprint sensor to the motherboard.
    • When replacing the fingerprint sensor, make sure the ribbon cable snaps into the port on the motherboard.
  6. HTC One Max Microphone and Speaker Assembly Replacement, Motherboard: paso 6, imagen 1 de 2 HTC One Max Microphone and Speaker Assembly Replacement, Motherboard: paso 6, imagen 2 de 2
    • Remove the two 2.2 mm Phillips #000 screws holding the battery cable.
    • Use a plastic tool to remove the ribbon cable.
  7. HTC One Max Microphone and Speaker Assembly Replacement: paso 7, imagen 1 de 2 HTC One Max Microphone and Speaker Assembly Replacement: paso 7, imagen 2 de 2
    • Use the plastic opening tool to disconnect the two antenna wires at the top of the phone.
    • Use the plastic opening tool to disconnect a third antenna wire at the bottom of the phone.
  8. HTC One Max Microphone and Speaker Assembly Replacement: paso 8, imagen 1 de 1
    • Remove the seven 3 mm Phillips #000 screws from the motherboard.
  9. HTC One Max Microphone and Speaker Assembly Replacement: paso 9, imagen 1 de 3 HTC One Max Microphone and Speaker Assembly Replacement: paso 9, imagen 2 de 3 HTC One Max Microphone and Speaker Assembly Replacement: paso 9, imagen 3 de 3
    • Use a plastic tool to pry up and disconnect the large ribbon cables on each side of the motherboard.
    • Use caution prying the ribbon cable on the right side because other ribbon cables run under it.
  10. HTC One Max Microphone and Speaker Assembly Replacement: paso 10, imagen 1 de 3 HTC One Max Microphone and Speaker Assembly Replacement: paso 10, imagen 2 de 3 HTC One Max Microphone and Speaker Assembly Replacement: paso 10, imagen 3 de 3
    • Remove the tape covering three flex cable gate connectors on the bottom left side of the phone.
    • Use small plastic opening tool to pry open the latch on each of these gate connectors to disconnect the three cables.
  11. HTC One Max Microphone and Speaker Assembly Replacement: paso 11, imagen 1 de 2 HTC One Max Microphone and Speaker Assembly Replacement: paso 11, imagen 2 de 2
    • Use a plastic tool to lift and remove the motherboard.
    • Use a heat gun to loosen adhesive at bottom if needed.
  12. HTC One Max Microphone and Speaker Assembly Replacement, Microphone and Speaker Assembly: paso 12, imagen 1 de 1
    • Remove the two 2.8 mm Phillips #000 screws from the metal plate near the bottom of the phone.
  13. HTC One Max Microphone and Speaker Assembly Replacement: paso 13, imagen 1 de 2 HTC One Max Microphone and Speaker Assembly Replacement: paso 13, imagen 2 de 2
    • Use the small plastic opening tool to pry back the speaker and microphone assembly from the bottom of the phone.
    • Be careful to not to damage the speaker.
Conclusión
3 personas más completaron esta guía.
Andrew Keller
Miembro Desde 09/23/14
1,131 Reputación
5 Guías creadas
Equipo
USF Tampa, Team 11-3, Blackwell Fall 2014 Miembro de USF Tampa, Team 11-3, Blackwell Fall 2014
USFT-BLACKWELL-F14S11G3
4 Miembros
7 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 2
Todo El Tiempo: 3,853
