Saltar al contenido principal
HTC One Max Fingerprint Sensor Replacement
Qué necesitas
  1. HTC One Max Fingerprint Sensor Replacement, Back Case: paso 1, imagen 1 de 1
    • Lift back cover while pressing highlighted release switch towards the center of the phone.
  2. HTC One Max Fingerprint Sensor Replacement: paso 2, imagen 1 de 2 HTC One Max Fingerprint Sensor Replacement: paso 2, imagen 2 de 2
    • Remove the four white stickers in each corner that cover the Tri-Wing screws.
    • Remove the white sticker near the buttons that control the volume.
    • Remove the white sticker near the SIM card.
    • Remove the big white sticker with the bar-code in the center of the phone.
  3. HTC One Max Fingerprint Sensor Replacement: paso 3, imagen 1 de 1
    • Remove the thirteen Tri-Wing Y00 screws (Upper & Lower screws are 5 mm length, middle screws are 3.8 mm length) from the back case.
    • Disconnect the cable near the volume buttons.
  4. HTC One Max Fingerprint Sensor Replacement: paso 4, imagen 1 de 2 HTC One Max Fingerprint Sensor Replacement: paso 4, imagen 2 de 2
    • Use the small plastic opening tool to pry between the screen and the rear case.
  5. HTC One Max Fingerprint Sensor Replacement, Fingerprint Sensor: paso 5, imagen 1 de 2 HTC One Max Fingerprint Sensor Replacement, Fingerprint Sensor: paso 5, imagen 2 de 2
    • Use Tweezers to disconnect the ribbon cable connecting the fingerprint sensor to the motherboard.
    • When replacing the fingerprint sensor, make sure the ribbon cable snaps into the port on the motherboard.
Conclusión
Andrey Sklyar
Miembro Desde 09/23/14
452 Reputación
2 Guías creadas
Equipo
USF Tampa, Team 11-3, Blackwell Fall 2014 Miembro de USF Tampa, Team 11-3, Blackwell Fall 2014
USFT-BLACKWELL-F14S11G3
4 Miembros
7 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 1,255
