Introducción
In this guide you willl learn how to replace a microphone in a HTC One Max.
Qué necesitas
Lift back cover while pressing highlighted release switch towards the center of the phone.
Herramienta utilizada en este paso:Tweezers$4.99
Use Tweezers to disconnect the ribbon cable connecting the fingerprint sensor to the motherboard.
When replacing the fingerprint sensor, make sure the ribbon cable snaps into the port on the motherboard.
Remove the two 2.2 mm Phillips #000 screws holding the battery cable.
Use a plastic tool to remove the ribbon cable.
Remove the tape covering three flex cable gate connectors on the bottom left side of the phone.
Use small plastic opening tool to pry open the latch on each of these gate connectors to disconnect the three cables.
Remove the three 3 mm Phillips #000 screws from the secondary board at the top.
Remove two screws from the bottom.
Set aside metal retaining plate.
Pry the battery away from the back of the screen with a plastic tool.
15 personas más completaron esta guía.
4 Guide Comments
Microphone in the article, battery in the title.
How to change LCD screen for this model?
