Introducción
Use this guide to replace the rear case on your HTC One M9.
Qué necesitas
Insert a SIM card eject tool or a paperclip into the small hole besides the SIM card tray, located on the upper section of the left edge of the phone.
Press to eject the tray.
The microSD card tray is located on the upper right hand side of the phone, above the volume buttons. To open the tray, insert a microSD card eject tool, or a paperclip, into the small hole in the microSD card tray.
Then press the tool or paperclip to eject the microSD card tray.
Using a plastic opening pick or a spudger, gently pry and remove the cover on top of the case.
Remove the two 4 mm T5 Torx screws on the top of the case.
11 personas más completaron esta guía.
4 comentarios
Great guide, changed my backcover in under 5 minutes. Thank you!
Cannot snap in the cover at the bottom. Afraid to force it a break screen. Please, help.
Take the case off, bend the little plastic lugs gently out, put the back on starting from the bottom
