Saltar al contenido principal
HTC MyTouch 4G Speakers Replacement
Qué necesitas
  1. HTC MyTouch 4G Speakers Replacement, Flip Phone Over: paso 1, imagen 1 de 1
    • Flip your phone over and hold the phone with the back facing you.
  2. HTC MyTouch 4G Speakers Replacement, Remove the back case.: paso 2, imagen 1 de 1
    • Place the prying tool into the notch at the bottom of the case and pull up to remove.
  3. HTC MyTouch 4G Speakers Replacement, Remove the battery: paso 3, imagen 1 de 2 HTC MyTouch 4G Speakers Replacement, Remove the battery: paso 3, imagen 2 de 2
    • Use the plastic prying tool in the upper left-hand corner notch of the battery to remove.
  4. HTC MyTouch 4G Speakers Replacement, Removing Screws: paso 4, imagen 1 de 1
    • Remove the two T5x5mm Screws with the T5 Torx Screw driver.
    • Remove the one Phillips screw with the Phillips #00 Screwdriver.
  5. HTC MyTouch 4G Speakers Replacement, Removing back case.: paso 5, imagen 1 de 3 HTC MyTouch 4G Speakers Replacement, Removing back case.: paso 5, imagen 2 de 3 HTC MyTouch 4G Speakers Replacement, Removing back case.: paso 5, imagen 3 de 3
    • Use the plastic opening tools to remove the back case.
    • There are four T5x5mm screws. Use the T5 Torx Screwdriver to remove them.
    • Using the plastic opening tools, remove the Wifi antenna.
  6. HTC MyTouch 4G Speakers Replacement, Removing four T5 Screws: paso 6, imagen 1 de 2 HTC MyTouch 4G Speakers Replacement, Removing four T5 Screws: paso 6, imagen 2 de 2
    • There are three button ribbons on the phone that need to be pulled down off of the case.
    • With the plastic opening tools, pull the button ribbons down away from the frame without completely removing them.
  7. HTC MyTouch 4G Speakers Replacement: paso 7, imagen 1 de 3 HTC MyTouch 4G Speakers Replacement: paso 7, imagen 2 de 3 HTC MyTouch 4G Speakers Replacement: paso 7, imagen 3 de 3
    • After making sure the button ribbons are away from the frame, insert the plastic opening tool into the frame and remove it.
    • Remove two Philips screws holding the Motherboard in place.
  8. HTC MyTouch 4G Speakers Replacement: paso 8, imagen 1 de 2 HTC MyTouch 4G Speakers Replacement: paso 8, imagen 2 de 2
    • Three ribbon cables and the vibration motor need to be disconnected from the Motherboard.
    • Using the plastic opening tools, pull up on the power button ribbon to gently detach it.
    • Remove the vibration motor by gently pulling it off of the Motherboard.
  9. HTC MyTouch 4G Speakers Replacement: paso 9, imagen 1 de 3 HTC MyTouch 4G Speakers Replacement: paso 9, imagen 2 de 3 HTC MyTouch 4G Speakers Replacement: paso 9, imagen 3 de 3
    • Remove the digitizer ribbon cable with the plastic opening tools.
    • Remove the LCD ribon cable from its connector.
    • It is now safe to release the Motherboard from the clips holding it in place. Start at the top clip of the phone and move your way around gently releasing each clip.
  10. HTC MyTouch 4G Speakers Replacement: paso 10, imagen 1 de 3 HTC MyTouch 4G Speakers Replacement: paso 10, imagen 2 de 3 HTC MyTouch 4G Speakers Replacement: paso 10, imagen 3 de 3
    • Do not lift the Motherboard off the phone. The LCD Ribbon is still connected to it.
    • Lift the Motherboard towards the left to expose the LCD clamp connector.
    • Open the clamp connector of the LCD ribbon by carefully pulling it up with the plastic opening tools.
  11. HTC MyTouch 4G Speakers Replacement: paso 11, imagen 1 de 1
    • The Motherboard is now removed.
  12. HTC MyTouch 4G Speakers Replacement, Speakers: paso 12, imagen 1 de 1
    • After the motherboard is removed, the speaker is now able to be replaced.
    • Use the plastic opening tools to pull out the old speaker and replace it with the new one.
Conclusión
leo
Miembro Desde 01/30/15
334 Reputación
3 Guías creadas
Equipo
USF Tampa, Team 16-5, Watkins Spring 2014 Miembro de USF Tampa, Team 16-5, Watkins Spring 2014
USFT-WATKINS-S14S16G5
2 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 161
