Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Introducción
Be careful with the trackball.
  1. First remove the back cover of your phone to expose the battery.
    • First remove the back cover of your phone to expose the battery.
  2. Turn the phone over.
    • Turn the phone over.
    • Push forward on the battery with your thumb.
  3. Take the battery out by lifting it upwards. When reassembling, make sure that the battery contacts match up.
    • Take the battery out by lifting it upwards.
    • When reassembling, make sure that the battery contacts match up.
  4. Remove the four 4.9mm T6 Torx screws that secure the back panel to the rest of the phone. Remove the four 4.9mm T6 Torx screws that secure the back panel to the rest of the phone.
    • Remove the four 4.9mm T6 Torx screws that secure the back panel to the rest of the phone.
  5. Remove the two 4.3mm Phillips #00 screws that secure the back panel to the rest of the phone.
    • Remove the two 4.3mm Phillips #00 screws that secure the back panel to the rest of the phone.
  6. Insert the plastic opening tool along the seams at different points to it pry the clips off. This may require a bit of force. The USB port cover may fall off in this step. This may require a bit of force. The USB port cover may fall off in this step.
    • Insert the plastic opening tool along the seams at different points to it pry the clips off.
    • This may require a bit of force. The USB port cover may fall off in this step.
  7. Remove the one 3.3mm Phillips #00 screw. Remove the one 3.3mm Phillips #00 screw.
    • Remove the one 3.3mm Phillips #00 screw.
  8. Use your finger or the plastic opening tool to unclip the board. Be aware of the ribbon cable connected to the motherboard inside the phone.
    • Use your finger or the plastic opening tool to unclip the board.
    • Be aware of the ribbon cable connected to the motherboard inside the phone.
  9. Peel off the yellow piece of tape from the phone. Peel off the yellow piece of tape from the phone.
    • Peel off the yellow piece of tape from the phone.
  10. Flip up the retaining flap with your fingernail or a plastic opening tool. Pull on the ribbon cable gently with your fingers. Pull on the ribbon cable gently with your fingers.
    • Flip up the retaining flap with your fingernail or a plastic opening tool.
    • Pull on the ribbon cable gently with your fingers.
  11. Split apart the motherboard and front panel. Remove the other yellow piece of tape off of the end of the ribbon cable.
    • Split apart the motherboard and front panel.
    • Remove the other yellow piece of tape off of the end of the ribbon cable.
  12. Gently pull on the ribbon cable to separate the motherboard. Gently pull on the ribbon cable to separate the motherboard.
    • Gently pull on the ribbon cable to separate the motherboard.
  13. Using your fingers, gently pull the trackball out. Using your fingers, gently pull the trackball out. Using your fingers, gently pull the trackball out.
    • Using your fingers, gently pull the trackball out.
Conclusión
Nick
Miembro Desde 28/10/11
6 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 20-29, Maness Fall 2011 Miembro de Cal Poly, Team 20-29, Maness Fall 2011
CPSU-MANESS-F11S20G29
4 Miembros
9 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 1,284
