Saltar al contenido principal
HTC Maple 100 External Speaker Replacement
Qué necesitas
  1. HTC Maple 100 External Speaker Replacement, Battery: paso 1, imagen 1 de 1
    • First remove the back cover of your phone to expose the battery.
  2. HTC Maple 100 External Speaker Replacement: paso 2, imagen 1 de 1
    • Turn the phone over.
    • Push forward on the battery with your thumb.
  3. HTC Maple 100 External Speaker Replacement: paso 3, imagen 1 de 2 HTC Maple 100 External Speaker Replacement: paso 3, imagen 2 de 2
    • Take the battery out by lifting it upwards.
    • When reassembling, make sure that the battery contacts match up.
  4. HTC Maple 100 External Speaker Replacement, Back Panel: paso 4, imagen 1 de 2 HTC Maple 100 External Speaker Replacement, Back Panel: paso 4, imagen 2 de 2
    • Remove the four 4.9mm T6 Torx screws that secure the back panel to the rest of the phone.
  5. HTC Maple 100 External Speaker Replacement: paso 5, imagen 1 de 1
    • Remove the two 4.3mm Phillips #00 screws that secure the back panel to the rest of the phone.
  6. HTC Maple 100 External Speaker Replacement: paso 6, imagen 1 de 3 HTC Maple 100 External Speaker Replacement: paso 6, imagen 2 de 3 HTC Maple 100 External Speaker Replacement: paso 6, imagen 3 de 3
    • Insert the plastic opening tool along the seams at different points to it pry the clips off.
    • This may require a bit of force. The USB port cover may fall off in this step.
  7. HTC Maple 100 External Speaker Replacement, External Speaker: paso 7, imagen 1 de 2 HTC Maple 100 External Speaker Replacement, External Speaker: paso 7, imagen 2 de 2
    • Using the plastic opening tool, pry the external speaker out of the back panel.
Conclusión
Alyssa Thompson
Miembro Desde 10/04/11
11 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 20-29, Maness Fall 2011 Miembro de Cal Poly, Team 20-29, Maness Fall 2011
CPSU-MANESS-F11S20G29
4 Miembros
18 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 1
Todo El Tiempo: 844
