Saltar al contenido principal
HTC Incredible 2 Volume Button Replacement
Qué necesitas
  1. HTC Incredible 2 Volume Button Replacement, Disassembling HTC Incredible 2 Back Panel: paso 1, imagen 1 de 2 HTC Incredible 2 Volume Button Replacement, Disassembling HTC Incredible 2 Back Panel: paso 1, imagen 2 de 2
    • Press your thumbnail into the slot between the rear panel and the front casing located on the bottom of the phone. Use a penny or dime if you have trouble using your thumbnail.
    • With a moderate amount of force, pry the rear panel up and away from the phone. You may need to slide your thumbnail up the crack to separate the rear panel from the front casing.
    • This can take a little bit of effort. Don't be discouraged if you can't get it right away.
  2. HTC Incredible 2 Volume Button Replacement: paso 2, imagen 1 de 1
    • Remove the rear panel from the phone.
  3. HTC Incredible 2 Volume Button Replacement, Battery: paso 3, imagen 1 de 1
    • Press your fingernail into the slot between the battery and the rear inner frame, located between the battery and LED lights.
    • Use a penny or dime if you can't use your fingernail.
  4. HTC Incredible 2 Volume Button Replacement: paso 4, imagen 1 de 2 HTC Incredible 2 Volume Button Replacement: paso 4, imagen 2 de 2
    • Gently lever the battery up and away from the lights.
    • Lift the top of the battery up and remove the battery from the rear inner frame.
  5. HTC Incredible 2 Volume Button Replacement, Mid Panel: paso 5, imagen 1 de 1
    • Remove the seven 1.42 mm Torx T5 screws
  6. HTC Incredible 2 Volume Button Replacement: paso 6, imagen 1 de 2 HTC Incredible 2 Volume Button Replacement: paso 6, imagen 2 de 2
    • Use a plastic opening tool to run along the phone's side and lever mid panel upward.
    • Apply minimal pressure as the mid panel is very delicate.
  7. HTC Incredible 2 Volume Button Replacement: paso 7, imagen 1 de 1
    • Gently grasp and carefully lift mid panel up and away from the device with your fingers.
  8. HTC Incredible 2 Volume Button Replacement, Volume Button: paso 8, imagen 1 de 3 HTC Incredible 2 Volume Button Replacement, Volume Button: paso 8, imagen 2 de 3 HTC Incredible 2 Volume Button Replacement, Volume Button: paso 8, imagen 3 de 3
    • Firmly grasp the volume button from the mid panel on the clip side
    • Gently lift the button upwards and remove it
Conclusión
2 personas más completaron esta guía.
Robert Trujillo
Miembro Desde 04/25/14
246 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 11-53, Amido Spring 2014 Miembro de Cal Poly, Team 11-53, Amido Spring 2014
CPSU-AMIDO-S14S11G53
5 Miembros
14 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 3
Todo El Tiempo: 319
