Introducción
Do you have a hard time turning on/off your phone? This guide will show you how to replace the power button.
Qué necesitas
Press your thumbnail into the slot between the rear panel and the front casing located on the bottom of the phone. Use a penny or dime if you have trouble using your thumbnail.
With a moderate amount of force, pry the rear panel up and away from the phone. You may need to slide your thumbnail up the crack to separate the rear panel from the front casing.
Press your fingernail into the slot between the battery and the rear inner frame, located between the battery and LED lights.
Apply pressure with your fingertip to the pressure clip beneath the SIM card.
While keeping pressure on the clip, use another finger to gently slide the SIM card down over the clip.
Firmly grasp the power button, located on the upper right corner of the mid panel, and gently lift it up and off the mid panel.
3 personas más completaron esta guía.
