Saltar al contenido principal
Introducción
Do you have a hard time turning on/off your phone? This guide will show you how to replace the power button.
Partes
No se especificaron partes.
  1. Press your thumbnail into the slot between the rear panel and the front casing located on the bottom of the phone. Use a penny or dime if you have trouble using your thumbnail. With a moderate amount of force, pry the rear panel up and away from the phone. You may need to slide your thumbnail up the crack to separate the rear panel from the front casing.
    • Press your thumbnail into the slot between the rear panel and the front casing located on the bottom of the phone. Use a penny or dime if you have trouble using your thumbnail.
    • With a moderate amount of force, pry the rear panel up and away from the phone. You may need to slide your thumbnail up the crack to separate the rear panel from the front casing.
    • This can take a little bit of effort. Don't be discouraged if you can't get it right away.
  2. Remove the rear panel from the phone.
    • Remove the rear panel from the phone.
  3. Press your fingernail into the slot between the battery and the rear inner frame, located between the battery and LED lights.
    • Press your fingernail into the slot between the battery and the rear inner frame, located between the battery and LED lights.
    • Use a penny or dime if you can't use your fingernail.
  4. Gently lever the battery up and away from the lights. Lift the top of the battery up and remove the battery from the rear inner frame.
    • Gently lever the battery up and away from the lights.
    • Lift the top of the battery up and remove the battery from the rear inner frame.
  5. Apply pressure with your fingertip to the pressure clip beneath the SIM card. While keeping pressure on the clip, use another finger to gently slide the SIM card down over the clip.
    • Apply pressure with your fingertip to the pressure clip beneath the SIM card.
    • While keeping pressure on the clip, use another finger to gently slide the SIM card down over the clip.
  6. Keep sliding SIM card until completely free from holding apparatus. Now remove the SIM card. Keep sliding SIM card until completely free from holding apparatus. Now remove the SIM card.
    • Keep sliding SIM card until completely free from holding apparatus. Now remove the SIM card.
  7. Remove the seven 1.42 mm Torx T5 screws
    • Remove the seven 1.42 mm Torx T5 screws
  8. Use a plastic opening tool to run along the phone's side and lever mid panel upward. Apply minimal pressure as the mid panel is very delicate.
    • Use a plastic opening tool to run along the phone's side and lever mid panel upward.
    • Apply minimal pressure as the mid panel is very delicate.
  9. Gently grasp and carefully lift mid panel up and away from the device with your fingers.
    • Gently grasp and carefully lift mid panel up and away from the device with your fingers.
  10. Firmly grasp the power button, located on the upper right corner of the mid panel, and gently lift it up and off the mid panel. Firmly grasp the power button, located on the upper right corner of the mid panel, and gently lift it up and off the mid panel. Firmly grasp the power button, located on the upper right corner of the mid panel, and gently lift it up and off the mid panel.
    • Firmly grasp the power button, located on the upper right corner of the mid panel, and gently lift it up and off the mid panel.
Conclusión
3 personas más completaron esta guía.
Equipo
Cal Poly, Team 11-53, Amido Spring 2014 Miembro de Cal Poly, Team 11-53, Amido Spring 2014
CPSU-AMIDO-S14S11G53
5 Miembros
7 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 7
Todo El Tiempo: 647
