Saltar al contenido principal
HTC Incredible 2 Micro SD Card Replacement
  1. HTC Incredible 2  Micro SD Card Replacement, Disassembling HTC Incredible 2 Back Panel: paso 1, imagen 1 de 2 HTC Incredible 2  Micro SD Card Replacement, Disassembling HTC Incredible 2 Back Panel: paso 1, imagen 2 de 2
    • Press your thumbnail into the slot between the rear panel and the front casing located on the bottom of the phone. Use a penny or dime if you have trouble using your thumbnail.
    • With a moderate amount of force, pry the rear panel up and away from the phone. You may need to slide your thumbnail up the crack to separate the rear panel from the front casing.
    • This can take a little bit of effort. Don't be discouraged if you can't get it right away.
  2. HTC Incredible 2  Micro SD Card Replacement: paso 2, imagen 1 de 1
    • Remove the rear panel from the phone.
  3. HTC Incredible 2  Micro SD Card Replacement, Micro SD Card: paso 3, imagen 1 de 2 HTC Incredible 2  Micro SD Card Replacement, Micro SD Card: paso 3, imagen 2 de 2
    • Use your fingertip to push inward on the SD card until you hear a click.
  4. HTC Incredible 2  Micro SD Card Replacement: paso 4, imagen 1 de 3 HTC Incredible 2  Micro SD Card Replacement: paso 4, imagen 2 de 3 HTC Incredible 2  Micro SD Card Replacement: paso 4, imagen 3 de 3
    • Remove your finger. The SD card is no longer being held in place.
    • Grasp it with two fingers and pull it towards you to remove it.
Conclusión
Ka Tong
Miembro Desde 04/26/14
131 Reputación
1 Guía escrita
Equipo
Cal Poly, Team 11-53, Amido Spring 2014 Miembro de Cal Poly, Team 11-53, Amido Spring 2014
CPSU-AMIDO-S14S11G53
5 Miembros
14 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 327
