Saltar al contenido principal
HTC Hero Touch Screen Digitizer Replacement
Qué necesitas
  1. HTC Hero Touch Screen Digitizer Replacement, Back Case: paso 1, imagen 1 de 1
    • Remove the back of the phone by pushing firmly with your thumbs up towards the camera.
    • Remove both the battery and the SD card (Press SD card in to release)
    • Locate and remove the four Torx screws highlighted in the photo, with the phone laying face down on your work space.
  2. HTC Hero Touch Screen Digitizer Replacement: paso 2, imagen 1 de 1
    • Carefully pry the inside back cover from the device using an appropriate size plastic opening tool or small flathead screwdriver.
    • Insert the flat end between the back and front enclosure, working your way around the rim.
  3. HTC Hero Touch Screen Digitizer Replacement: paso 3, imagen 1 de 1
    • Gently depress and release the small plastic tabs around the rim in the front enclosure, highlighted here.
    • It is best to start with the tab found on the top center of the phone, as it is easiest to locate.
  4. HTC Hero Touch Screen Digitizer Replacement: paso 4, imagen 1 de 2 HTC Hero Touch Screen Digitizer Replacement: paso 4, imagen 2 de 2
    • Carefully separate the front and back enclosures once all of the clips have been disengaged.
    • Be sure to not separate too quickly or you risk breaking an attached tab.
  5. HTC Hero Touch Screen Digitizer Replacement, Touch Screen: paso 5, imagen 1 de 2 HTC Hero Touch Screen Digitizer Replacement, Touch Screen: paso 5, imagen 2 de 2
    • Gently release the two ribbon cables using a plastic opening tool by prying up the pop connectors used to attach the ribbon cables to the motherboard.
  6. HTC Hero Touch Screen Digitizer Replacement: paso 6, imagen 1 de 2 HTC Hero Touch Screen Digitizer Replacement: paso 6, imagen 2 de 2
    • Remove the two screws located at the bottom left and right of the motherboard using a small Phillips screwdriver.
  7. HTC Hero Touch Screen Digitizer Replacement: paso 7, imagen 1 de 2 HTC Hero Touch Screen Digitizer Replacement: paso 7, imagen 2 de 2
    • Gently lift the motherboard out of the front enclosure once the screws are removed.
  8. HTC Hero Touch Screen Digitizer Replacement: paso 8, imagen 1 de 3 HTC Hero Touch Screen Digitizer Replacement: paso 8, imagen 2 de 3 HTC Hero Touch Screen Digitizer Replacement: paso 8, imagen 3 de 3
    • Remove the trackball and its enclosure by turning the phone over into your cupped hand and allowing the trackball and enclosure to fall out.
  9. HTC Hero Touch Screen Digitizer Replacement: paso 9, imagen 1 de 3 HTC Hero Touch Screen Digitizer Replacement: paso 9, imagen 2 de 3 HTC Hero Touch Screen Digitizer Replacement: paso 9, imagen 3 de 3
    • Gently pry out the LCD screen from the left side of the enclosure as illustrated, using an plastic opening tool.
    • Using a heat lamp or gun warm the glass in order to loosen the adhesive binding it to the frame.
  10. HTC Hero Touch Screen Digitizer Replacement: paso 11, imagen 1 de 2 HTC Hero Touch Screen Digitizer Replacement: paso 11, imagen 2 de 2
    • Using a plastic opening tool, gently pry the glass from the frame by inserting the flat end between the glass and the frame from the inside of the phone.
    • Follow the edges of the glass to ensure that all the adhesive has been released.
  11. HTC Hero Touch Screen Digitizer Replacement: paso 12, imagen 1 de 1
    • Once the adhesive has been released, you should be able to remove the glass by pushing on it from the inside of the phone.
    • Be careful to remove the glass slowly because the ribbon cable connected to the glass is routed through the plastic frame at the bottom.
  12. HTC Hero Touch Screen Digitizer Replacement: paso 13, imagen 1 de 3 HTC Hero Touch Screen Digitizer Replacement: paso 13, imagen 2 de 3 HTC Hero Touch Screen Digitizer Replacement: paso 13, imagen 3 de 3
    • Carefully feed the ribbon cable through the slot in the plastic frame.
  13. HTC Hero Touch Screen Digitizer Replacement: paso 14, imagen 1 de 1
    • Remove any excess adhesive from the plastic frame.
Conclusión
Max Brown
Miembro Desde 01/23/12
139 Reputación
4 Guías creadas
Equipo
Cal Poly, Team 3-26, Amido Winter 2012 Miembro de Cal Poly, Team 3-26, Amido Winter 2012
CPSU-AMIDO-W12S3G26
5 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 2
Todo El Tiempo: 3,406
