Saltar al contenido principal
HTC Hero Motherboard Replacement
Qué necesitas
  1. HTC Hero Motherboard Replacement, Back Case: paso 1, imagen 1 de 1
    • Remove the back of the phone by pushing firmly with your thumbs up towards the camera.
    • Remove both the battery and the SD card (Press SD card in to release)
    • Locate and remove the four Torx screws highlighted in the photo, with the phone laying face down on your work space.
  2. HTC Hero Motherboard Replacement: paso 2, imagen 1 de 1
    • Carefully pry the inside back cover from the device using an appropriate size plastic opening tool or small flathead screwdriver.
    • Insert the flat end between the back and front enclosure, working your way around the rim.
  3. HTC Hero Motherboard Replacement: paso 3, imagen 1 de 1
    • Gently depress and release the small plastic tabs around the rim in the front enclosure, highlighted here.
    • It is best to start with the tab found on the top center of the phone, as it is easiest to locate.
  4. HTC Hero Motherboard Replacement: paso 4, imagen 1 de 2 HTC Hero Motherboard Replacement: paso 4, imagen 2 de 2
    • Carefully separate the front and back enclosures once all of the clips have been disengaged.
    • Be sure to not separate too quickly or you risk breaking an attached tab.
  5. HTC Hero Motherboard Replacement, Motherboard: paso 5, imagen 1 de 2 HTC Hero Motherboard Replacement, Motherboard: paso 5, imagen 2 de 2
    • Release the two ribbon cables using a plastic opening tool.
    • Gently pry up the pop connectors used to attach the ribbon cables to the motherboard.
  6. HTC Hero Motherboard Replacement: paso 6, imagen 1 de 2 HTC Hero Motherboard Replacement: paso 6, imagen 2 de 2
    • Remove the two screws located at the bottom left and right of the motherboard using a small Phillips screwdriver.
  7. HTC Hero Motherboard Replacement: paso 7, imagen 1 de 2 HTC Hero Motherboard Replacement: paso 7, imagen 2 de 2
    • Gently lift the motherboard out of the front enclosure once the screws are removed.
Conclusión
Equipo
Cal Poly, Team 3-26, Amido Winter 2012 Miembro de Cal Poly, Team 3-26, Amido Winter 2012
CPSU-AMIDO-W12S3G26
5 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 11
Todo El Tiempo: 1,560
