Herramientas
Partes
No se especificaron partes.
Remove the back of the phone by pushing firmly with your thumbs up towards the camera.
Remove both the battery and the SD card (Press SD card in to release)
Locate and remove the four Torx screws highlighted in the photo, with the phone laying face down on your work space.
Release the two ribbon cables using a plastic opening tool.
Gently pry up the pop connectors used to attach the ribbon cables to the motherboard.
At this point it is a good idea to remove the track ball and enclosure to prevent accidental loss.
To remove the trackball, turn the phone over into your cupped hand and the trackball will fall out.
