Introducción
This guide will assist you in removing the motherboard and rigid flex board in the HTC HD2.
Qué necesitas
Carefully pull the rear cover from the back of the phone.
Place a finger beneath the small lip on the left side of the battery.
Insert the flat end of a spudger between the midframe and the display.
Slide the spudger along the seam between the frame and the display.
Using the spudger for leverage, carefully pry the midframe away from the display assembly.
As it releases, pull the midframe away from the phone.
Herramienta utilizada en este paso:Tweezers$4.99
Set the phone down on its screen.
Using tweezers, unplug the small vibrator connector from its socket on the motherboard.
Disconnect the small speaker cable from its socket on the motherboard.
Remove the earpiece speaker from the phone.
4 personas más completaron esta guía.
