Saltar al contenido principal
HTC Flyer MicroUSB Port Replacement
Qué necesitas
  1. HTC Flyer MicroUSB Port Replacement, Back Cover: paso 1, imagen 1 de 3 HTC Flyer MicroUSB Port Replacement, Back Cover: paso 1, imagen 2 de 3 HTC Flyer MicroUSB Port Replacement, Back Cover: paso 1, imagen 3 de 3
    • Apply pressure along the bottom of the white panel containing the camera and push upwards.
    • It may take some effort, but it will smoothly slide off.
  2. HTC Flyer MicroUSB Port Replacement: paso 2, imagen 1 de 3 HTC Flyer MicroUSB Port Replacement: paso 2, imagen 2 de 3 HTC Flyer MicroUSB Port Replacement: paso 2, imagen 3 de 3
    • Unscrew the four of 3.5mm Torx T5 screws that run along the sides of the exposed innards.
    • All screws in the device will use the Torx T5 screwdriver, so keep it handy.
  3. HTC Flyer MicroUSB Port Replacement: paso 3, imagen 1 de 3 HTC Flyer MicroUSB Port Replacement: paso 3, imagen 2 de 3 HTC Flyer MicroUSB Port Replacement: paso 3, imagen 3 de 3
    • Remove the black protective piece of plastic by sliding it upwards.
    • Remove the two 3.5mm Torx #5 screws holding the protective plastic down on along the sides.
    • A center 3.5mm Torx screw will be covered by "VOID" sticker.
    • Either remove the sticker or jam the screwdriver into the screw, and remove the screw.
    • Remove the protective panel by sliding it upwards.
  4. HTC Flyer MicroUSB Port Replacement: paso 4, imagen 1 de 2 HTC Flyer MicroUSB Port Replacement: paso 4, imagen 2 de 2
    • Before removing the back cover, apply some scotch tape to the volume buttons to prevent them from falling out of the back panel.
    • Use a plastic opening tool to lever up the top half of the cover.
    • Lift the back panel up and remove it from the device.
  5. HTC Flyer MicroUSB Port Replacement, Battery: paso 5, imagen 1 de 2 HTC Flyer MicroUSB Port Replacement, Battery: paso 5, imagen 2 de 2
    • Gently unfold the black tape along the top that covers the cable attachment points.
    • Leave the tape partially attached so that it can be easily re-attached.
  6. HTC Flyer MicroUSB Port Replacement: paso 6, imagen 1 de 3 HTC Flyer MicroUSB Port Replacement: paso 6, imagen 2 de 3 HTC Flyer MicroUSB Port Replacement: paso 6, imagen 3 de 3
    • Use the tip of a spudger as a lever to disconnect the four cable connectors.
    • Gently pull out these cables after releasing the back piece.
  7. HTC Flyer MicroUSB Port Replacement: paso 7, imagen 1 de 1
    • Remove the single 2.5mm Torx T5 screw holding the battery down along the top side.
  8. HTC Flyer MicroUSB Port Replacement: paso 8, imagen 1 de 3 HTC Flyer MicroUSB Port Replacement: paso 8, imagen 2 de 3 HTC Flyer MicroUSB Port Replacement: paso 8, imagen 3 de 3
    • Wedge the flat end of a spudger inbetween the battery and the front panel assembly.
    • Run the flat end of a spudger along the top edge of the battery to separate it from the adhesive securing it to the front panel assembly.
    • If you encounter any resistance from the remaining adhesive, simply use the flat end of a spudger to remove the excess adhesive.
  9. HTC Flyer MicroUSB Port Replacement, MicroUSB Port: paso 9, imagen 1 de 1
    • Use a spudger to unclip the the wires attached to the power jack
    • The clips have a white or black relief tab that, when pressed, releases the wires.
  10. HTC Flyer MicroUSB Port Replacement: paso 10, imagen 1 de 2 HTC Flyer MicroUSB Port Replacement: paso 10, imagen 2 de 2
    • Remove the two 2.5mm Torx T5 screws from both sides of the power jack panel.
  11. HTC Flyer MicroUSB Port Replacement: paso 11, imagen 1 de 2 HTC Flyer MicroUSB Port Replacement: paso 11, imagen 2 de 2
    • Gently remove the power jack panel.
Conclusión
4 personas más completaron esta guía.
Joshua
Miembro Desde 10/07/14
185 Reputación
1 Guía escrita
Equipo
USF Tampa, Team 8-5, Leahy Fall 2014 Miembro de USF Tampa, Team 8-5, Leahy Fall 2014
USFT-LEAHY-F14S8G5
3 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 1
Todo El Tiempo: 1,168
