Saltar al contenido principal
HTC Flyer Back Cover Replacement
Qué necesitas
  1. HTC Flyer Back Cover Replacement, Back Cover: paso 1, imagen 1 de 3 HTC Flyer Back Cover Replacement, Back Cover: paso 1, imagen 2 de 3 HTC Flyer Back Cover Replacement, Back Cover: paso 1, imagen 3 de 3
    • Apply pressure along the bottom of the white panel containing the camera and push upwards.
    • It may take some effort, but it will smoothly slide off.
  2. HTC Flyer Back Cover Replacement: paso 2, imagen 1 de 3 HTC Flyer Back Cover Replacement: paso 2, imagen 2 de 3 HTC Flyer Back Cover Replacement: paso 2, imagen 3 de 3
    • Unscrew the four of 3.5mm Torx T5 screws that run along the sides of the exposed innards.
    • All screws in the device will use the Torx T5 screwdriver, so keep it handy.
  3. HTC Flyer Back Cover Replacement: paso 3, imagen 1 de 3 HTC Flyer Back Cover Replacement: paso 3, imagen 2 de 3 HTC Flyer Back Cover Replacement: paso 3, imagen 3 de 3
    • Remove the black protective piece of plastic by sliding it upwards.
    • Remove the two 3.5mm Torx #5 screws holding the protective plastic down on along the sides.
    • A center 3.5mm Torx screw will be covered by "VOID" sticker.
    • Either remove the sticker or jam the screwdriver into the screw, and remove the screw.
    • Remove the protective panel by sliding it upwards.
  4. HTC Flyer Back Cover Replacement: paso 4, imagen 1 de 2 HTC Flyer Back Cover Replacement: paso 4, imagen 2 de 2
    • Before removing the back cover, apply some scotch tape to the volume buttons to prevent them from falling out of the back panel.
    • Use a plastic opening tool to lever up the top half of the cover.
    • Lift the back panel up and remove it from the device.
Conclusión
2 personas más completaron esta guía.
Justin Funk
Miembro Desde 10/07/14
473 Reputación
3 Guías creadas
Equipo
USF Tampa, Team 8-5, Leahy Fall 2014 Miembro de USF Tampa, Team 8-5, Leahy Fall 2014
USFT-LEAHY-F14S8G5
3 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 9
Todo El Tiempo: 399
