Saltar al contenido principal
HTC Excalibur Battery Replacement
Qué necesitas
  1. HTC Excalibur Battery Replacement, Battery: paso 1, imagen 1 de 1
    • Power the phone off. Remove the back cover of the Phone, exposing the battery.
    • Grasp the battery by the two indents on either side of it, near the bottom. Lift up, pulling the battery loose. Remove the battery completely.
  2. HTC Excalibur Battery Replacement: paso 2, imagen 1 de 1
    • Take the new battery and orient it correctly -- the arrow should be facing towards the camera lens, face up.
    • Insert the battery at an angle, pushing the battery in until it is aligned on the top edge. Push the rest of the battery in, snapping it into place.
    • Reattach the battery cover, and power up your phone.
Conclusión
Una persona más ha completado esta guía.
Ian Mitchell
Miembro Desde 04/19/11
142 Reputación
5 Guías creadas
Equipo
Cal Poly, Team 25-27, Garner Spring 2011 Miembro de Cal Poly, Team 25-27, Garner Spring 2011
CPSU-GARNER-S11S25G27
4 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 2,082
