Saltar al contenido principal
HTC Evo 4G MicroSD card Replacement
Qué necesitas
  1. HTC Evo 4G MicroSD card Replacement, Rear Panel: paso 1, imagen 1 de 1
    • Gently insert an iPod opening tool between the rear panel and the inner rear frame near the headphone jack.
    • Use your iPod opening tool to pry up the rear case around the perimeter of the Evo.
  2. HTC Evo 4G MicroSD card Replacement: paso 2, imagen 1 de 1
    • Lift the rear panel off of the inner rear frame.
  3. HTC Evo 4G MicroSD card Replacement, Battery: paso 3, imagen 1 de 2 HTC Evo 4G MicroSD card Replacement, Battery: paso 3, imagen 2 de 2
    • Using the tip of your finger, lift the battery from the end closest to the camera.
    • Remove the battery from the rear inner frame.
  4. HTC Evo 4G MicroSD card Replacement, MicroSD card: paso 4, imagen 1 de 1
    • Use the flat end of a spudger to pry up the red MicroSD retainer attached to the inner frame.
    • The retainer will move about 1 mm and stop. Do not attempt to completely remove the MicroSD card retainer.
  5. HTC Evo 4G MicroSD card Replacement: paso 5, imagen 1 de 1
    Herramienta utilizada en este paso:
    Comprar
    • Use a pair of tweezers to carefully pull the MicroSD card out of its slot in the inner rear frame.
Conclusión
7 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 4
Todo El Tiempo: 10,416
