Saltar al contenido principal
Qué necesitas
  1. HTC Evo 3D Vibrate Mechanism Replacement, Vibrate Mechanism: paso 1, imagen 1 de 3 HTC Evo 3D Vibrate Mechanism Replacement, Vibrate Mechanism: paso 1, imagen 2 de 3 HTC Evo 3D Vibrate Mechanism Replacement, Vibrate Mechanism: paso 1, imagen 3 de 3
    • Remove the outer casing of the phone with your hands by prying and lifting at the latch.
  2. HTC Evo 3D Vibrate Mechanism Replacement: paso 2, imagen 1 de 2 HTC Evo 3D Vibrate Mechanism Replacement: paso 2, imagen 2 de 2
    • Remove the battery with your hands, lifting at the marked area.
  3. HTC Evo 3D Vibrate Mechanism Replacement: paso 3, imagen 1 de 1
    • Remove the SD card
    • Remove the four T5 screws using the corresponding screwdriver.
    • Remove the two J000 screws using the corresponding screwdriver.
  4. HTC Evo 3D Vibrate Mechanism Replacement: paso 4, imagen 1 de 2 HTC Evo 3D Vibrate Mechanism Replacement: paso 4, imagen 2 de 2
    • With the battery removed, the inner case of the phone can now be removed.
    • Using the plastic opening tool, pry the inner case off at the marked area. Continue prying around the entire perimeter of the phone.
    • This will remove the inner case, and allow access into the inner portion of the phone.
    • Be careful not rip or damage the ribbons inside this shell.
  5. HTC Evo 3D Vibrate Mechanism Replacement: paso 5, imagen 1 de 3 HTC Evo 3D Vibrate Mechanism Replacement: paso 5, imagen 2 de 3 HTC Evo 3D Vibrate Mechanism Replacement: paso 5, imagen 3 de 3
    • The vibrating mechanism is located on the motherboard, on the right.
    • The marked part is the vibrating mechanism.
    • To remove the vibrating mechanism, use the tweezers to securely hold the wire and tug on it.
    • The vibrating unit can then be disconnected from the motherboard using the tweezers, grasping the white part.
Conclusión
James Burke
Miembro Desde 26/08/15
245 Reputación
2 Guías creadas
Equipo
USF Tampa, Team 14-20, Meier Fall 2015 Miembro de USF Tampa, Team 14-20, Meier Fall 2015
USFT-MEIER-F15S14G20
5 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 3
Todo El Tiempo: 206
