Saltar al contenido principal
Qué necesitas
Este desmontaje no es una guía de reparación. Para reparar tu HTC Evo 3D, utiliza nuestros manuales de servicio .
  1. HTC Evo 3D Teardown, HTC Evo 3D Teardown: paso 1, imagen 1 de 1
    • First things first, Remove the back cover, battery and SD card.
  2. HTC Evo 3D Teardown: paso 2, imagen 1 de 1
    • Remove the four T5 Torx screws.
    • Then remove the two Phillips screws.
    • *Very sorry for dark image*
  3. HTC Evo 3D Teardown: paso 3, imagen 1 de 1
    • Once the screws are all out from the exterior back case, Begin separating the front housing from the back by using a spudger or any similar tool.
    • Begin from the bottom were the battery bay is, It is the easiest way.
    • Be careful of ribbons behind the plastic
  4. HTC Evo 3D Teardown: paso 4, imagen 1 de 3 HTC Evo 3D Teardown: paso 4, imagen 2 de 3 HTC Evo 3D Teardown: paso 4, imagen 3 de 3
    • Once separated begin to remove the LED board. Apply only light upward force and it will detach itself.
  5. HTC Evo 3D Teardown: paso 5, imagen 1 de 2 HTC Evo 3D Teardown: paso 5, imagen 2 de 2
    • Vibrator come's out easy, Just grab it by the wire and give it a little tug and it should come out.
    • Start unlocking the clips holding the ribbons. pull the white tab up to unlock.
    • Example: bottom left is unlocked, bottom right is locked. upper left has bin finished and removed.
    • Tuck the ribbons in without bending or making tears in them.
  6. HTC Evo 3D Teardown: paso 6, imagen 1 de 1
    • Behind the main board is two more ribbon's.
    • Flip both tab locks holding the ribbons and they will slide out vary easily, Don't force it.
    • Wifi/cellular antena port, Lift up cord head directly to remove and press straight down centered to put back on.
    • As a side note, the grey tape on the back side of the board was covering the clips so i cut a small section for this guide.
  7. HTC Evo 3D Teardown: paso 7, imagen 1 de 1
    • This concludes the (simple) teardown of the Evo 3D.
_Z_
Miembro Desde 03/18/12
9,668 Reputación
2 Guías creadas
Equipo
Master Techs Miembro de Master Techs
Community
322 Miembros
2,520 Guías creadas
Un comentario
Thanks. This was very helpful.
dano706 - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 7
Todo El Tiempo: 19,431
