Saltar al contenido principal
HTC EVO 4G Speaker Replacement
Qué necesitas
  1. HTC EVO 4G Speaker Replacement, Battery: paso 1, imagen 1 de 2 HTC EVO 4G Speaker Replacement, Battery: paso 1, imagen 2 de 2
    • Remove the back case of the phone with a plastic opening tool by placing the tool in the tab on the back of the phone.
  2. HTC EVO 4G Speaker Replacement: paso 2, imagen 1 de 2 HTC EVO 4G Speaker Replacement: paso 2, imagen 2 de 2
    • Remove the battery from the phone by carefully lifting it out with your fingers.
  3. HTC EVO 4G Speaker Replacement: paso 3, imagen 1 de 1
    • Set the battery aside for disposal. You are now ready to insert a new battery.
  4. HTC EVO 4G Speaker Replacement, Speaker: paso 4, imagen 1 de 1
    • you should remove the six T5 screws holding the Inner frame in place. Be careful not to loose the screws
  5. HTC EVO 4G Speaker Replacement: paso 5, imagen 1 de 3 HTC EVO 4G Speaker Replacement: paso 5, imagen 2 de 3 HTC EVO 4G Speaker Replacement: paso 5, imagen 3 de 3
    • Using the plastic opening tool again, gently pry the inner frame apart from the rest of the phone
    • Remove the inner frame from the rest of the phone by lifting it off
  6. HTC EVO 4G Speaker Replacement: paso 6, imagen 1 de 1
    • use plastic pic to gently pry our the speaker
    • be sure to have your replacement unit ready
Conclusión
Sage Jurado
Miembro Desde 03/13/14
1,128 Reputación
4 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 186
