Saltar al contenido principal
HTC Droid Eris Battery Replacement
Qué necesitas
  1. HTC Droid Eris Battery Replacement, Battery: paso 1, imagen 1 de 2 HTC Droid Eris Battery Replacement, Battery: paso 1, imagen 2 de 2
    • Place the device on a flat surface with the headphone outlet facing you.
    • Place the tip of one of your fingers over the highlighted spot.
    • Next, pull the back cover upwards. If this feels difficult, use the spudger.
  2. HTC Droid Eris Battery Replacement: paso 2, imagen 1 de 2 HTC Droid Eris Battery Replacement: paso 2, imagen 2 de 2
    • Lay the device on a flat surface with the screen facing downward. Use one hand to hold the device in place.
    • With your free hand, stick one of your fingers in the marked gap. Pull gently upwards towards you.
    • If the battery is not coming out with this technique, use the plastic opening tool.
Conclusión
Equipo
SUNY Cortland, Team 1-2, Getto Spring 2013 Miembro de SUNY Cortland, Team 1-2, Getto Spring 2013
SUNYCORT-GETTO-S13S1G2
5 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 754
