Introducción
Use this guide to replace your HTC Droid DNA's battery.
Qué necesitas
Poke a paperclip into the hole to the right of the SIM Card Tray. The SIM Card Tray will automatically pop out.
Starting at a corner, slowly work your way around the edge of the sides with your prying tool to loosen the front panel.
Set the device down so that the bottom of the phone is facing to the right.
Gently take off the piece of black tape surrounding the motherboard.
Use your tweezers to take off the yellow tape on the bottom left corner of the phone.
Use the Phillips #000 screwdriver to remove the single 2.7mm void screw on the bottom right.
Rotate your phone back 90 Degrees counter-clockwise.
Use your tweezers to take off the small metal retaining bracket on the bottom right of the phone.
Remove the following Phillips #000 screws from the motherboard:
Four 1.6 mm screws
Two 1.5 mm screws
Use your pry tool to unfasten the connectors on both sides of the motherboard.
Use your tweezers to remove the two pieces of yellow tape shown.
Use your tweezers to gently snap up the white board on the bottom right of the motherboard.
Use your tweezers to disconnect the black connector on the bottom right of the motherboard.
Use your tweezers to gently snap the other white board on the bottom right of the motherboard up.
Use your tweezers to disconnect the other small connector on the bottom right of the motherboard.
Rotate the phone 180 degrees.
Use your tweezers to gently snap up the white board on the top left of the motherboard.
Use your tweezers to disconnect the cable on the top left of the motherboard.
Use your tweezers to gently snap up the black board on the top left of the motherboard.
Use your tweezers to gently remove the yellow connector on the top left of the phone.
Reorient the phone so that the green camera board is farthest from you.
Use your tweezers to remove the two wires located at the top of the board. The wires snap off very easily so not much force is needed.
Use a Phillips #000 screwdriver to remove the two 3.9mm screws on top of motherboard.
Now, use your fingers to slowly pull up the motherboard and remove it from the phone.
Use the pry tool to separate the housing of the phone from the battery.
Slowly pull up the battery with the prying tool.
Remove the battery with your fingers.
16 personas más completaron esta guía.
2 comentarios
Thanks for posting this hope I now get a few more years out of my DNA for not much money.
