Saltar al contenido principal
HTC Desire V Vibration Motor Replacement
Qué necesitas
  1. HTC Desire V Vibration Motor Replacement, Battery: paso 1, imagen 1 de 3 HTC Desire V Vibration Motor Replacement, Battery: paso 1, imagen 2 de 3 HTC Desire V Vibration Motor Replacement, Battery: paso 1, imagen 3 de 3
    • Gently pry back cover away from phone.
    • If you are having difficulty you may need to use a Spudger or plastic opener.
  2. HTC Desire V Vibration Motor Replacement: paso 2, imagen 1 de 3 HTC Desire V Vibration Motor Replacement: paso 2, imagen 2 de 3 HTC Desire V Vibration Motor Replacement: paso 2, imagen 3 de 3
    • Lever the battery out from the bottom end first.
    • Do not bend or puncture the battery.
  3. HTC Desire V Vibration Motor Replacement, Midframe: paso 3, imagen 1 de 3 HTC Desire V Vibration Motor Replacement, Midframe: paso 3, imagen 2 de 3 HTC Desire V Vibration Motor Replacement, Midframe: paso 3, imagen 3 de 3
    • Use a Torx T5 screwdriver to unscrew and remove five 3.0 mm screws from the rear frame.
  4. HTC Desire V Vibration Motor Replacement: paso 4, imagen 1 de 3 HTC Desire V Vibration Motor Replacement: paso 4, imagen 2 de 3 HTC Desire V Vibration Motor Replacement: paso 4, imagen 3 de 3
    • Use an opening tool or a spudger to gently remove the rear frame.
  5. HTC Desire V Vibration Motor Replacement, Vibration Motor: paso 5, imagen 1 de 2 HTC Desire V Vibration Motor Replacement, Vibration Motor: paso 5, imagen 2 de 2
    • Unplug the vibration motor shown from the white plug on the motherboard.
    • You will probably need tweezers to do this.
  6. HTC Desire V Vibration Motor Replacement: paso 6, imagen 1 de 2 HTC Desire V Vibration Motor Replacement: paso 6, imagen 2 de 2
    • Gently remove the motor from its housing in the phone’s chassis.
    • The easiest way to do this is to lever the motor out by its rotating end using the tweezers.
Conclusión
Una persona más ha completado esta guía.
William McCusker
Miembro Desde 01/29/15
1,096 Reputación
9 Guías creadas
Equipo
Clemson, Team 14-3, Shirley Winter 2015 Miembro de Clemson, Team 14-3, Shirley Winter 2015
CLEM-SHIRLEY-W15S14G3
6 Miembros
18 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 367
