Saltar al contenido principal
HTC Desire V Motherboard Replacement
Qué necesitas
  1. HTC Desire V Motherboard Replacement, Battery: paso 1, imagen 1 de 3 HTC Desire V Motherboard Replacement, Battery: paso 1, imagen 2 de 3 HTC Desire V Motherboard Replacement, Battery: paso 1, imagen 3 de 3
    • Gently pry back cover away from phone.
    • If you are having difficulty you may need to use a Spudger or plastic opener.
  2. HTC Desire V Motherboard Replacement: paso 2, imagen 1 de 3 HTC Desire V Motherboard Replacement: paso 2, imagen 2 de 3 HTC Desire V Motherboard Replacement: paso 2, imagen 3 de 3
    • Lever the battery out from the bottom end first.
    • Do not bend or puncture the battery.
  3. HTC Desire V Motherboard Replacement, Midframe: paso 3, imagen 1 de 3 HTC Desire V Motherboard Replacement, Midframe: paso 3, imagen 2 de 3 HTC Desire V Motherboard Replacement, Midframe: paso 3, imagen 3 de 3
    • Use a Torx T5 screwdriver to unscrew and remove five 3.0 mm screws from the rear frame.
  4. HTC Desire V Motherboard Replacement: paso 4, imagen 1 de 3 HTC Desire V Motherboard Replacement: paso 4, imagen 2 de 3 HTC Desire V Motherboard Replacement: paso 4, imagen 3 de 3
    • Use an opening tool or a spudger to gently remove the rear frame.
  5. HTC Desire V Motherboard Replacement, Button Assembly: paso 5, imagen 1 de 2 HTC Desire V Motherboard Replacement, Button Assembly: paso 5, imagen 2 de 2
    • Remove the connector on left side of the Navigation board by unplugging/prying the orange ribbon.
  6. HTC Desire V Motherboard Replacement: paso 6, imagen 1 de 2 HTC Desire V Motherboard Replacement: paso 6, imagen 2 de 2
    • Gently unplug and remove aerial cable (black antenna) from bottom plug.
  7. HTC Desire V Motherboard Replacement: paso 7, imagen 1 de 2 HTC Desire V Motherboard Replacement: paso 7, imagen 2 de 2
    • Nav Board will be stuck down by glue.
    • Pull gently from the right end of the board, being careful of its flexibility.
  8. HTC Desire V Motherboard Replacement, Vibration Motor: paso 8, imagen 1 de 2 HTC Desire V Motherboard Replacement, Vibration Motor: paso 8, imagen 2 de 2
    • Unplug the vibration motor shown from the white plug on the motherboard.
    • You will probably need tweezers to do this.
  9. HTC Desire V Motherboard Replacement: paso 9, imagen 1 de 2 HTC Desire V Motherboard Replacement: paso 9, imagen 2 de 2
    • Gently remove the motor from its housing in the phone’s chassis.
    • The easiest way to do this is to lever the motor out by its rotating end using the tweezers.
  10. HTC Desire V Motherboard Replacement, Motherboard Assembly: paso 10, imagen 1 de 2 HTC Desire V Motherboard Replacement, Motherboard Assembly: paso 10, imagen 2 de 2
    • Remove the black information sticker if this is the first time opening the handset.
  11. HTC Desire V Motherboard Replacement: paso 11, imagen 1 de 3 HTC Desire V Motherboard Replacement: paso 11, imagen 2 de 3 HTC Desire V Motherboard Replacement: paso 11, imagen 3 de 3
    • You should now see a black ribbon cable, which was connected at the left to the Nav board, and on the right, to a gold ribbon cable which goes to the screen.
    • Unlock the gold ribbon cable connecting screen to logic board by lifting the locking tab at the back of the socket.
    • For this you may wish to use a spudger or tweezers.
  12. HTC Desire V Motherboard Replacement: paso 12, imagen 1 de 2 HTC Desire V Motherboard Replacement: paso 12, imagen 2 de 2
    • Disconnect gold ribbon cable connecting screen to logic board by pulling cable out gently.
  13. HTC Desire V Motherboard Replacement: paso 13, imagen 1 de 3 HTC Desire V Motherboard Replacement: paso 13, imagen 2 de 3 HTC Desire V Motherboard Replacement: paso 13, imagen 3 de 3
    • Gently unstick black ribbon cable from the chassis.
  14. HTC Desire V Motherboard Replacement: paso 14, imagen 1 de 2 HTC Desire V Motherboard Replacement: paso 14, imagen 2 de 2
    • Unscrew the 2mm silver screw from top left.
    • Use a Phillips PH00 Screwdriver for this.
  15. HTC Desire V Motherboard Replacement: paso 15, imagen 1 de 2 HTC Desire V Motherboard Replacement: paso 15, imagen 2 de 2
    • Gently pry logic board from the casing by lifting the left side up, as if there was a hinge on the right, folding it over the right edge where you will see a gold/orange ribbon cable.
  16. HTC Desire V Motherboard Replacement: paso 16, imagen 1 de 3 HTC Desire V Motherboard Replacement: paso 16, imagen 2 de 3 HTC Desire V Motherboard Replacement: paso 16, imagen 3 de 3
    • Remove the gold ribbon cable by lifting tab at the back of the socket, using a spudger or tweezers.
  17. HTC Desire V Motherboard Replacement: paso 17, imagen 1 de 2 HTC Desire V Motherboard Replacement: paso 17, imagen 2 de 2
    • Gently pull the logic board to the right and it will disconnect from the chassis.
Conclusión
Una persona más ha completado esta guía.
William McCusker
Miembro Desde 01/29/15
1,096 Reputación
9 Guías creadas
Equipo
Clemson, Team 14-3, Shirley Winter 2015 Miembro de Clemson, Team 14-3, Shirley Winter 2015
CLEM-SHIRLEY-W15S14G3
6 Miembros
18 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 259
