Saltar al contenido principal
HTC Desire V Button Assembly Replacement
Qué necesitas
  1. HTC Desire V Button Assembly Replacement, Battery: paso 1, imagen 1 de 3 HTC Desire V Button Assembly Replacement, Battery: paso 1, imagen 2 de 3 HTC Desire V Button Assembly Replacement, Battery: paso 1, imagen 3 de 3
    • Gently pry back cover away from phone.
    • If you are having difficulty you may need to use a Spudger or plastic opener.
  2. HTC Desire V Button Assembly Replacement: paso 2, imagen 1 de 3 HTC Desire V Button Assembly Replacement: paso 2, imagen 2 de 3 HTC Desire V Button Assembly Replacement: paso 2, imagen 3 de 3
    • Lever the battery out from the bottom end first.
    • Do not bend or puncture the battery.
  3. HTC Desire V Button Assembly Replacement, Midframe: paso 3, imagen 1 de 3 HTC Desire V Button Assembly Replacement, Midframe: paso 3, imagen 2 de 3 HTC Desire V Button Assembly Replacement, Midframe: paso 3, imagen 3 de 3
    • Use a Torx T5 screwdriver to unscrew and remove five 3.0 mm screws from the rear frame.
  4. HTC Desire V Button Assembly Replacement: paso 4, imagen 1 de 3 HTC Desire V Button Assembly Replacement: paso 4, imagen 2 de 3 HTC Desire V Button Assembly Replacement: paso 4, imagen 3 de 3
    • Use an opening tool or a spudger to gently remove the rear frame.
  5. HTC Desire V Button Assembly Replacement, Button Assembly: paso 5, imagen 1 de 2 HTC Desire V Button Assembly Replacement, Button Assembly: paso 5, imagen 2 de 2
    • Remove the connector on left side of the Navigation board by unplugging/prying the orange ribbon.
  6. HTC Desire V Button Assembly Replacement: paso 6, imagen 1 de 2 HTC Desire V Button Assembly Replacement: paso 6, imagen 2 de 2
    • Gently unplug and remove aerial cable (black antenna) from bottom plug.
  7. HTC Desire V Button Assembly Replacement: paso 7, imagen 1 de 2 HTC Desire V Button Assembly Replacement: paso 7, imagen 2 de 2
    • Nav Board will be stuck down by glue.
    • Pull gently from the right end of the board, being careful of its flexibility.
Conclusión
3 personas más completaron esta guía.
William McCusker
Miembro Desde 01/29/15
1,096 Reputación
9 Guías creadas
Equipo
Clemson, Team 14-3, Shirley Winter 2015 Miembro de Clemson, Team 14-3, Shirley Winter 2015
CLEM-SHIRLEY-W15S14G3
6 Miembros
18 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 12
Todo El Tiempo: 316
