Saltar al contenido principal
HTC Desire HTC Desire Speaker Replacement
Qué necesitas
  1. HTC Desire HTC Desire Speaker Replacement, Battery: paso 1, imagen 1 de 2 HTC Desire HTC Desire Speaker Replacement, Battery: paso 1, imagen 2 de 2
    • Insert flat end of spudger into slot on the top of phone to pry off the back plate.
  2. HTC Desire HTC Desire Speaker Replacement: paso 2, imagen 1 de 2 HTC Desire HTC Desire Speaker Replacement: paso 2, imagen 2 de 2
    • Use flat edge of spudger to lift the bottom right corner of the battery.
    • Lift the battery out of the phone.
  3. HTC Desire HTC Desire Speaker Replacement, Vibrator: paso 3, imagen 1 de 1
    • Remove the lower, two 0.5 mm screws using Torx T5 screwdriver.
  4. HTC Desire HTC Desire Speaker Replacement: paso 4, imagen 1 de 2 HTC Desire HTC Desire Speaker Replacement: paso 4, imagen 2 de 2
    • Use spudger to pry vibrator panel off.
  5. HTC Desire HTC Desire Speaker Replacement: paso 5, imagen 1 de 2 HTC Desire HTC Desire Speaker Replacement: paso 5, imagen 2 de 2
    • Use spudger to remove the vibrator.
  6. HTC Desire HTC Desire Speaker Replacement, HTC Desire Speaker: paso 6, imagen 1 de 2 HTC Desire HTC Desire Speaker Replacement, HTC Desire Speaker: paso 6, imagen 2 de 2
    • Take out the upper, two 0.5 mm Torx screws with a Torx T5 bit.
  7. HTC Desire HTC Desire Speaker Replacement: paso 7, imagen 1 de 1
    • Take the middle 0.3 mm phillips screw out with the phillips J000 tip.
  8. HTC Desire HTC Desire Speaker Replacement: paso 8, imagen 1 de 3 HTC Desire HTC Desire Speaker Replacement: paso 8, imagen 2 de 3 HTC Desire HTC Desire Speaker Replacement: paso 8, imagen 3 de 3
    • Using the spudger, pry up to remove the battery holder.
  9. HTC Desire HTC Desire Speaker Replacement: paso 9, imagen 1 de 3 HTC Desire HTC Desire Speaker Replacement: paso 9, imagen 2 de 3 HTC Desire HTC Desire Speaker Replacement: paso 9, imagen 3 de 3
    • Using the spudger, pry the speaker out of its place.
  10. HTC Desire HTC Desire Speaker Replacement: paso 10, imagen 1 de 1
    • With the springs up, place the new speaker into position.
Conclusión
4 personas más completaron esta guía.
Scott Olson
Miembro Desde 10/22/15
274 Reputación
1 Guía escrita
Equipo
Montana Tech, Team 10-2, Shirk Fall 2015 Miembro de Montana Tech, Team 10-2, Shirk Fall 2015
MTUM-SHIRK-F15S10G2
4 Miembros
8 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 11
Todo El Tiempo: 1,178
