Saltar al contenido principal
HTC Desire 826 Motherboard Replacement
Qué necesitas
  1. HTC Desire 826 Motherboard Replacement, Battery: paso 1, imagen 1 de 3 HTC Desire 826 Motherboard Replacement, Battery: paso 1, imagen 2 de 3 HTC Desire 826 Motherboard Replacement, Battery: paso 1, imagen 3 de 3
    • Find a seam in the back of the device.
    • Insert the plastic spudger into the seam and pry off the back panel.
    • There will be glue, so keep prying until it comes off or you may need to heat up the edges of the device to loosen the adhesive with the iOpener.
  2. HTC Desire 826 Motherboard Replacement: paso 2, imagen 1 de 3 HTC Desire 826 Motherboard Replacement: paso 2, imagen 2 de 3 HTC Desire 826 Motherboard Replacement: paso 2, imagen 3 de 3
    Herramienta utilizada en este paso:
    Comprar
    • Remove the 4.0 mm screw above the battery with a T5 Torx screwdriver.
    • Remove the metal bracket with the tweezers.
  3. HTC Desire 826 Motherboard Replacement: paso 3, imagen 1 de 1
    • Disconnect the battery cable from the motherboard with the tweezers.
  4. HTC Desire 826 Motherboard Replacement: paso 4, imagen 1 de 2 HTC Desire 826 Motherboard Replacement: paso 4, imagen 2 de 2
    • Lift the battery with a plastic spudger and remove it from the device.
  5. HTC Desire 826 Motherboard Replacement, Motherboard: paso 5, imagen 1 de 2 HTC Desire 826 Motherboard Replacement, Motherboard: paso 5, imagen 2 de 2
    • Remove the three 4.0 mm T5 Torx screws connected to the motherboard.
  6. HTC Desire 826 Motherboard Replacement: paso 6, imagen 1 de 2 HTC Desire 826 Motherboard Replacement: paso 6, imagen 2 de 2
    • Disconnect the ribbon cable from the motherboard by flipping up the locking tab with a spudger and pulling out the cable with your fingers.
    • Lift the motherboard out of the frame, using a spudger to help pick up one of the edges.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 2
Ultimos 30 días: 6
Todo El Tiempo: 224
