Saltar al contenido principal
HTC Desire 826 Front Camera Replacement
Qué necesitas
  1. HTC Desire 826 Front Camera Replacement, Battery: paso 1, imagen 1 de 3 HTC Desire 826 Front Camera Replacement, Battery: paso 1, imagen 2 de 3 HTC Desire 826 Front Camera Replacement, Battery: paso 1, imagen 3 de 3
    • Find a seam in the back of the device.
    • Insert the plastic spudger into the seam and pry off the back panel.
    • There will be glue, so keep prying until it comes off or you may need to heat up the edges of the device to loosen the adhesive with the iOpener.
  2. HTC Desire 826 Front Camera Replacement: paso 2, imagen 1 de 3 HTC Desire 826 Front Camera Replacement: paso 2, imagen 2 de 3 HTC Desire 826 Front Camera Replacement: paso 2, imagen 3 de 3
    Herramienta utilizada en este paso:
    Comprar
    • Remove the 4.0 mm screw above the battery with a T5 Torx screwdriver.
    • Remove the metal bracket with the tweezers.
  3. HTC Desire 826 Front Camera Replacement: paso 3, imagen 1 de 1
    • Disconnect the battery cable from the motherboard with the tweezers.
  4. HTC Desire 826 Front Camera Replacement: paso 4, imagen 1 de 2 HTC Desire 826 Front Camera Replacement: paso 4, imagen 2 de 2
    • Lift the battery with a plastic spudger and remove it from the device.
  5. HTC Desire 826 Front Camera Replacement, Front Camera: paso 5, imagen 1 de 3 HTC Desire 826 Front Camera Replacement, Front Camera: paso 5, imagen 2 de 3 HTC Desire 826 Front Camera Replacement, Front Camera: paso 5, imagen 3 de 3
    • Use the T5 screwdriver to remove the three 4.0 mm screws as shown.
    • Once the screws are removed, pry up the top plastic panel using the black nylon spudger.
  6. HTC Desire 826 Front Camera Replacement: paso 6, imagen 1 de 2 HTC Desire 826 Front Camera Replacement: paso 6, imagen 2 de 2
    Comprar
    • Use the tweezers to detach the cameras wire from the top motherboard
    • Then use the tweezers to remove the camera
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 6
Todo El Tiempo: 162
