Saltar al contenido principal
HTC Desire 826 Back Camera Replacement
Qué necesitas
  1. HTC Desire 826 Back Camera Replacement, Battery: paso 1, imagen 1 de 3 HTC Desire 826 Back Camera Replacement, Battery: paso 1, imagen 2 de 3 HTC Desire 826 Back Camera Replacement, Battery: paso 1, imagen 3 de 3
    • Find a seam in the back of the device.
    • Insert the plastic spudger into the seam and pry off the back panel.
    • There will be glue, so keep prying until it comes off or you may need to heat up the edges of the device to loosen the adhesive with the iOpener.
  2. HTC Desire 826 Back Camera Replacement: paso 2, imagen 1 de 3 HTC Desire 826 Back Camera Replacement: paso 2, imagen 2 de 3 HTC Desire 826 Back Camera Replacement: paso 2, imagen 3 de 3
    Herramienta utilizada en este paso:
    Comprar
    • Remove the 4.0 mm screw above the battery with a T5 Torx screwdriver.
    • Remove the metal bracket with the tweezers.
  3. HTC Desire 826 Back Camera Replacement: paso 3, imagen 1 de 1
    • Disconnect the battery cable from the motherboard with the tweezers.
  4. HTC Desire 826 Back Camera Replacement: paso 4, imagen 1 de 2 HTC Desire 826 Back Camera Replacement: paso 4, imagen 2 de 2
    • Lift the battery with a plastic spudger and remove it from the device.
  5. HTC Desire 826 Back Camera Replacement, Back Camera: paso 5, imagen 1 de 3 HTC Desire 826 Back Camera Replacement, Back Camera: paso 5, imagen 2 de 3 HTC Desire 826 Back Camera Replacement, Back Camera: paso 5, imagen 3 de 3
    • Use a T5 Torx screwdriver to remove the three 4.0 mm screws.
  6. HTC Desire 826 Back Camera Replacement: paso 6, imagen 1 de 1
    • Use the spudger to lift the black plastic covering.
  7. HTC Desire 826 Back Camera Replacement: paso 7, imagen 1 de 3 HTC Desire 826 Back Camera Replacement: paso 7, imagen 2 de 3 HTC Desire 826 Back Camera Replacement: paso 7, imagen 3 de 3
    Comprar
    • Use the spudger to lift the green board. The back camera is attached on the side as shown.
    • Use the tweezers to disconnect and remove the camera.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 6
Todo El Tiempo: 218
