Saltar al contenido principal
HTC Desire 700 Dual Sim Bottom Speaker Replacement
Qué necesitas
  1. HTC Desire 700 Dual Sim Bottom Speaker Replacement, Back Cover: paso 1, imagen 1 de 1
    • Use the spudger to pry the back cover off.
  2. HTC Desire 700 Dual Sim Bottom Speaker Replacement, Removing Battery: paso 2, imagen 1 de 1
    • Use spudger tool to pry under the battery to lift it up and out.
  3. HTC Desire 700 Dual Sim Bottom Speaker Replacement, Remove 8 Torx Screws: paso 3, imagen 1 de 1
    • Remove eight 8.3mm T4 screws with the Torx screwdriver.
  4. HTC Desire 700 Dual Sim Bottom Speaker Replacement, Prying Off Rear Panel: paso 4, imagen 1 de 1
    • Pry the back panel of the screen using the plastic opener.
    • Work your way gently around the device, using picks as necessary to keep the back panel separated.
    • Use caution not to damage the device, as it takes force to remove the rear panel.
  5. HTC Desire 700 Dual Sim Bottom Speaker Replacement, Printed Circuit Board (PCB): paso 5, imagen 1 de 1
    Herramienta utilizada en este paso:
    Comprar
    • Disconnect wire going from the printed circuit board to the motherboard using the tweezers.
  6. HTC Desire 700 Dual Sim Bottom Speaker Replacement: paso 6, imagen 1 de 1
    • Using the plastic prying tool, pry the PCB device from the screen of the phone.
  7. HTC Desire 700 Dual Sim Bottom Speaker Replacement, Bottom Speaker: paso 7, imagen 1 de 1
    • Using the spudger, pry the speaker away from the screen.
Conclusión
3 personas más completaron esta guía.
Steven Pate
Miembro Desde 09/23/14
191 Reputación
7 Guías creadas
Equipo
USF Tampa, Team 9-3, Blackwell Fall 2014 Miembro de USF Tampa, Team 9-3, Blackwell Fall 2014
USFT-BLACKWELL-F14S9G3
4 Miembros
14 Guías creadas
Un comentario
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 7
Todo El Tiempo: 892
