Saltar al contenido principal
HTC Desire 626s Loud Speaker Replacement
Qué necesitas
  1. HTC Desire 626s Loud Speaker Replacement, Backplate: paso 1, imagen 1 de 3 HTC Desire 626s Loud Speaker Replacement, Backplate: paso 1, imagen 2 de 3 HTC Desire 626s Loud Speaker Replacement, Backplate: paso 1, imagen 3 de 3
    • Insert plastic opening tool in between the back cover and grey plastic.
    • Gently work your way around the phone while sliding the tool.
    • Gently pry on plastic cover as needed to release fasteners.
  2. HTC Desire 626s Loud Speaker Replacement: paso 2, imagen 1 de 2 HTC Desire 626s Loud Speaker Replacement: paso 2, imagen 2 de 2
    • There are 7 screws you need to remove before prying the secondary cover off. You will need to use the JIS #000 screwdriver and the T5 Torx screwdriver to remove these screws.
    • There is a screw under the "void" sticker.
  3. HTC Desire 626s Loud Speaker Replacement: paso 3, imagen 1 de 2 HTC Desire 626s Loud Speaker Replacement: paso 3, imagen 2 de 2
    • Once the screws are removed, use the plastic opening tool to remove the remaining plastic cover.
    • Start from the corners of the phone, and insert the plastic opening tool between the outer colored rim and the screen.
    • This portion of the cover will be more difficult to remove than the initial back cover. Be patient and gentle around the button holes.
  4. HTC Desire 626s Loud Speaker Replacement, Loud Speaker: paso 4, imagen 1 de 1
    Herramienta utilizada en este paso:
    Comprar
    • Use tweezers to lift the speaker straight up.
    • You can locate the loudspeaker at the base of the phone; it should have a white sticker on it.
  5. HTC Desire 626s Loud Speaker Replacement: paso 5, imagen 1 de 2 HTC Desire 626s Loud Speaker Replacement: paso 5, imagen 2 de 2
    • Wiggle the loudspeaker with the tweezers if it does not at first come out.
    • Congratulations you have successfully removed the loudspeaker.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 7
Todo El Tiempo: 229
